Question about HP LaserJet M3035 MFP Printer
Paper late jam. Jam in casette - HP LaserJet M3035 MFP Printer
5 Suggested Answers
jaylex
  • 417 Answers
SOURCE: False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
Posted on Dec 31, 2007
SOURCE: Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Posted on Mar 31, 2008
  • 7 Answers
SOURCE: HP Laserjet 2420- Late Paper Jam
1) Your paper tray may be too full, makes it heavy to lift and not enough pressure for the pick up roller.
2) Pick up roller is slippery, wipe it clean with alcohol to make it abbrasive.
Posted on Jul 08, 2008
  • 224 Answers
SOURCE: Getting the error on my HP 4345mfp - TOP OUTPUT
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Posted on Mar 31, 2010
Free a 13.20.00 paper jam in a hp 4005dn. Doesnt tell me where it is and cannot find any paper jam. Red light flashing
If you cannot find any paper but the printer is still displaying a jam, then it is most likely a paper late jam check the pick-up roller and if it is smooth, time to replace it. Other wise, you will need a tech to clean out the paper path and make sure there are no scraps.
Feb 26, 2015 | HP Office Equipment & Supplies
I HAVE A CANON PIXMA MP830 INK JET PRINTER WHICH HAS A PAPER JAM CAN YOU HELP
Here are the basic steps that can resolve your issue.
- Paper jam in the Paper feeder or in the output slot
pull out the paper slowly, if the paper tears open the printer cover(scanning unit) and remove the paper (careful not to touch any printer components) after removing the paper restart the printer, then redo the printing process.
-Paper jam inside the machine
Open the rear cover, if you seen the paper remove it, then close the back cover then restart the printer and redo the printing process, if your unable to get the paper from the rear cover, open the casette infront of the printer and slowly pull out the paper, return the casette and restart the machine..
If your still unable to get the paper,
remove the casette, stand the machine with the left side on the buttom (make sure its not the right side) pull out the paper while pulling the green cover toward you, return the casette, restart the machine and redo the printing.
If your having difficulties or still unable to remove the paper contact the canon support center in your area.
Here is a link where you can see visual step by step procedures.
I hope this will help you a lot.
Thank you for choosing fixya.
Mar 03, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Dear sir, I have a 4 IR 5000 machine. One machine complaint is paper jam, the paper jam err code is 0102. how can solve the problem please reply immediately
This means that there is a delay jam on the second sensor from the paper casette. You will have have to replace the pickup rollers, or try cleaning them.
Dec 21, 2010 | Canon imageRUNNER 5000 Copier
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
It says there ia a paper jam and there is not one. We have looked for one everywhere and can't find a paper jam
open all of the paper casettes.make sure no jam there. then with the cassettes open open and close all of the covers. it is possible you have a bad sensor saying a false jam
Jan 25, 2010 | Canon ImageClass MF6540 Copier
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
HP 4700n Paper Late Jam
duplex area related jam in other printers. is problem only occurring in tray 1. If so, there is a problem with the tray. If it's happening from tray 1 and tray 2, replace try replacing transfer belt.
May 27, 2008 | Office Equipment & Supplies
Apr 15, 2008 | HP LaserJet 2420 Printer
Feb 20, 2008 | HP LaserJet 2420 Printer
Sharp al 1655 false paper jam message,
Check that the paper feed roller is clean as if the roller slips it causes a late paper pickup jam but nothing will be in there also maybe a small torn piece in the machine some where. and check the fuser make sure that is it not stuck in there if no to all these then is will need a control board.
Thanks J
Nov 17, 2007 | Sharp AL-1655CS Laser Printer
HP LaserJet M3035 MFP Printer Logo
496 people viewed this question
Seeker5211
Seeker5211
