Sleep timer on my 1992 sj2771w zenith thv
I dont have the manual for my zenith sj2771w, and i would like to be able to use the sleep timer but i cant figure out how, can anyone help?
  • spicyb2 Oct 23, 2008
    i dont need to buy a new remote for it, i have a universal remote and i have gotten to the sleep timer with it before except it was by accident and i dont know how i did it. so i just need to know if any knows where i can maybe download the user guide or just knows how to use the sleep timer. thanks
  • 790 Answers
Hi
Buy A remote Control for your Unit! try this Links Clickhere
Thanks!
Posted on Oct 23, 2008
Set sleep timer tv
Refer its user manual for details. If you do not have the user manual, check this link to download it. http://www.retrevo.com
May 08, 2013 | Westinghouse 24" Class 1080p 60hz LED LCD...
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
How do I use the sleep timer? when I push the sleep timer button it gives me on time and off time to set. I dont know how to use this. Cant I just set sleep timer for 30 minutes to turn off? Thank you.
Hello
Before going to set the timer, you have to set the current time. Set it according to the manual with you. If the timer function work properly, there must be an uninerrupted power supply also. If the power goes off, the set time will also get resetted, and improper function will occur.
After setting the present time, set the "on" time and "Off" time. The TV will switch on at that time you set, and will switch off automatically after the end time. OK.
Dec 23, 2010 | RCA 20F420T 20" TV
HP w1907 LCD Monitor goes to sleep by displaying a "monitor is going to sleep"error after turning on the computer and doesnt display anything. It works intermittently, in that, if the computer has been...
so if you test the monitor on a known good PC it does what?
fails, then its the monitor
works then its the failing PC
all old HP monitors pre 2010 many had a sleep timer
so push the menu key on the monitor
then look for sleep timer and turn it off,
the monitor defaults to that mode, so dont push reset monitor or bam back to sleep mode it goes. so turn it off again.
all this is in the manual, lost yours, wana read it first?
read page 4.7 see that? (osd +advanced +) power saver OFF
https://www.manualslib.com/manual/418165/Hp-W1907-19-Lcd-Monitor.html?page=25#manual
if that fails to fix it (tested on 2 PC ) the PC1 is bad.
that be a whole other WALL OF TEXt, ask.
Dec 10, 2017 | HP w1907 LCD Monitor
My old zenith (probably early 90s) only gets up to channel 48 when there are more channels provided by my cable service. I have used the autosearch, and thats what number it goes to.
[1] use LG exteanel setup box chenal convater 90 to 200 ch avalabel in market .
[2] use inside of tv extra chenal convater pcb. PHLIPS.
[3] change complet new tv chasis with new latest function and all new facilety
EXP.
UOC Technologey chasis
NTSC /PAL /SCAME / AUTO Multi Colour System
Auto Search tunig
A/v 1 -2 -3 Stereo.
A.v Out facility
DVD Comonent input
surround sound mode
1300w pmpo woofer System
on timer /off timer /clock /sleep timer facilety
calender
5 pictur mode
Curtain Effect.
all facilety Avalabel in TOSIBA /SANYO chesis
pls Cont. your Nr.tv techicien
Oct 30, 2009 | Zenith C27A24T 27" TV
How to turn the sleep timer off
You obviously don't have a menu button on the set itself. Unplug the unit and remove the back cover, this should expose the info you need unless it was placed on the outside and is now lost. Without TV model it will be difficult to get any helpful assistance. Good luck.
Jul 05, 2009 | Televison & Video
Vertical height shortened on 9-1074 module.
Hi
Can you give me the exact problem? im waiting for your reply...
Thanks!
Oct 23, 2008 | Zenith C27A24T 27" TV
2 Problems
this answer has given also to some one had the same problem.
"On your remote should be a button called TV caption or text. Turn off the closed caption as someone hit it and turned it on by accident. If its not on your remote, then it is in the menu." Good Luck
You can also get a user manual at the link below:
http://www.retrevo.com/s/Zenith-C27A24T-TVs-review-manual/id/277ag102/t/1-2/
Jan 20, 2008 | Zenith C27A24T 27" TV
Zenith B27A11Z remote stop working
remove the batteries from remote ,then put im back and then try again
Jan 01, 2008 | Zenith B27A11Z 27" TV
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
