Question about Krups Coffee Makers & Espresso Machines
My Krups XP2000 steamer for milk doesn't work
  • 2039 Answers
SOURCE: Milk frother /steamer not working
if you could remove the pipe put the pipe in a solution to remove the calcium in thr pipe dry calcium is like concrete dip it and use a piece of wire to clean cheers
Posted on Jan 19, 2008
  • 123 Answers
SOURCE: Krups FND1 water escape
What position do you have the knob in? According to your manul it should be in position 9 not in position 8 for steaming.Good Luck.
Posted on Apr 11, 2008
dutchman05
  • 487 Answers
SOURCE: Milk Steamer takes too long
means the temp is not high enough or pressure not high enough
1) descale the machine real good
2) if not workin your thermostat or brewer can be broken.
Let me know if you still have problems after this descaling
And by the way poke a needle through the steam spout as that can be clogged too..
have fun
Posted on May 05, 2008
  • 833 Answers
SOURCE: Steamer and milk frother not working
This sounds like one of several problems:
1. Does any indicator light come on? If there is one and it doesn't you either have a bad thermostat (size of a dime/1/4 inch thick) black item with two wires attached to the chamber or a bad heater. Check both with an ohm meter...Resistance of any kind across the terminals means okay.
2. Could be the switch. Same kind of test.
3. If you've got a steam leak, deal with that...new cap or valve.
Make sure all wire fasters are clean and bright. If screwed down, make sure they are tight. Cycle each connector off and on to clean them.
Remember: always work on your unit with it unplugged. You may need torx screwdrivers to open this unit. Any hardware store will have sets of these items.
Posted on Jun 16, 2008
  • 833 Answers
SOURCE: I need replace coffee pot
Try Walmart or one of the home stores first. If not...smallappliance.com
The frother on my krups 'il primo' has lost power. The steam barely comes out. How can I fix that?
I've also had this problem with the Krups 'Il Primo' - reduced steam for frothing of milk but plenty of espresso.
Diagnosis: over many uses, a residue of dried milk plugs the interior of the steamer tip.
Fix: Using a small adjustable wrench, remove the tip. Clean it inside and out with a tooth pick. Reattach the tip - gentle with the wrench.
Aug 01, 2012 | Coffee Makers & Espresso Machines
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
My milk steamer is no longer steaming. Some steam comes out but not enough to steam the milk. The expresso part is working fine as I recently used a Krups descaling kit on it.
From your message that it is clear that the steam is coming but it is not sufficient to heat the milk, so kindly call the customer care to sort the problem as you can't do it
Thank you.
May 08, 2010 | Krups XP4030 Espresso Machine
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
Pump for the Milk Steamer is pumping permanent
This is a ******** side no help from the "experts".Look at the Date!
Dec 10, 2008 | Krups Novo 3000 /FNC3 Espresso Machine
Milk froths at 1st then doesn't after 1 week
Ensure first that you are using the steam pipe in the correct way to froth the milk.
If it still does not work, that means that the steamer is not generating enough pressure steam.
If you think you are doing everything in the right way, then contact the company and insist for having the machine fixed or replaced.
Nov 07, 2008 | Krups XP 1500 Espresso Machine & Coffee...
Hi, we have a Krups espresso machine, model fnd1. We can't seem to make the milk steamer work, it will make the milk REALLY hot, but not foamy. Do you replenish the steam supply somewhere? Is there a...
suggestions include very cold milk.  having the nozzle just barely in for frothing.
On my model there's an air passage in the nozzle that foams quite nicely.  If you have that too, it might be clogged with milk.  You have to keep these clean with every use.
Jul 11, 2008 | Krups XP4030 Espresso Machine
Milk Steamer takes too long to heat milk. By the time it is heated sufficiently, there is too much water in the milk form the steamer.
have fun
May 04, 2008 | Krups Novo 3000 /FNC3 Espresso Machine
Apr 11, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
105 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
