Question about Emerson MW8107WA Microwave Oven
No power to my mircowave what can i do?
No power nothing is working
How to fix mircowave
Other then checking the plug and wall socket...Have you checked the fuse? It's inside under the vent panel. Most hardware stores carry common fuses.
Mar 20, 2014 | GE JVM1190 Microwave Oven
How do I find a phone number for defectiveEmerson Mircowavess
The information should be on your owner's manual and your service contract paperwork.
Emesron support is here http://www.emersonradio.com/support.php or you can call:
Customer Service
Toll Free: 1.800.909.1240
Days: Monday - Friday
Hours: 9:00am - 5:30pm EST
Apr 26, 2013 | Emerson Microwave Ovens
Ge mircowave message is P F
"PF" means that the power has been interrupted, so you need to set the clock, then the oven should work.
If you actually do have a problem with this oven, it will have to be replaced, since GE does not make repair parts available for it.
Jan 16, 2013 | GE Microwave Ovens
Frigidaire mircowave not working
If you are talking about no power, the fuse is open. But you have power the problem is one of three things, magnetron, cracked high voltage diode, and a shorted high voltage capacitor.
Mar 19, 2012 | Frigidaire Microwave Ovens
I have a GE household microwave (model JEM318A002) manufactured 7/1999. It is built into our cabinetry. Periodically it will freeze (nothing showing on the display...no response to keys; sometimes have...
Hello
sometimes you can find a small hole on the bottom or the back of the mircowave.. like the watches you stick a pen in to reset;; this is a reset for the mircowave you need a pin and do it just like the watches,
Also There bis a fuse on the inside panel or back panel after removing it.. the fuse or wires can be croded causing temporay memory loss ,if you clean it up it should hold memory how ever they do not recomend you open or remove the panel rom miorcowave only a experanced person should do this,it is up to you how to handle that
I gave you the information I know but also the safty about it if you do not feel good about opening it I just wouldn't do it
Good Luck
Apr 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The mircowave has no power, outlet works, just mirco strop workin
HI, the popping sound that you herd was the result of a failed HV capacitor. This failure will render the unit inoperable, as you has witnessed at this time. Replacing this failed HV capacitor, will correct this issue. I would also advise to check the cut-off fuse and in-line AC fuse as well. There may be some issues concerning the integrity of these fuses as well.
Sep 11, 2009 | Goldstar MV-1501 Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
Help, my mircowave
It may have a short, if i were you i wouldn't be using it check to see if your mircowave is on a recall list if its not and your mircowave is under warranty see if you can replace it with a new one
Feb 18, 2008 | Microwave Ovens
Emerson MW8107WA Microwave Oven Logo
41 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
