Se ha instalado un cartucho de tinta de forma incorrecta
  • 53 Answers
SOURCE: tengo una impresora lexmark Z2320 recargue los
Lexmark no es compatible con los cartuchos rellenados.
Posted on May 18, 2009
SOURCE: parpadean los dos botones el de el bote y la de la tinta
alex, te tengo malas noticias yo tambien trabajo con estas impresoras llevo 4 dañadas de igual manera, la epson en estados unidos te la cambia antes del año de garantia, es de pensar que seben que tiene su defecto que parece ser no tiene remedio, si llegas a encontara el reseteador me lo pasas yo hare igual contigo.
Posted on Nov 13, 2009
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
pineworks
  • 4041 Answers
SOURCE: Cartucho de tinta preto incompatível
INK TANK
Posted on Mar 22, 2010
puertobori
  • 7733 Answers
SOURCE: RESIDO EN LA CIUDAD DE
Visite la pgina Lexmark - United States,cambie su Pais y busque como comprar.Via internet o tienda.
Posted on Oct 26, 2010
ES IMPRESORA Y SCANNER. NO PUEDO USARLA SOLO COMO SCANNER AUNQUE NO TENGA TINTA????
Muchos de los lectores tienen una funci?n de copia que utiliza la impresora . Usted puede ser capaz de comprar cartuchos de tinta para que o tal vez rellenado de los cartuchos de tinta si el coste es un problema. Creo que ser?a necesario de tinta para poder utilizar el esc?ner debido a la funci?n de copia.
Dec 31, 2014 | Office Equipment & Supplies
Impresora bloqueada y no detecta cartuchos de tinta
Trate de limpiar los inyectores de los cartuchos. Si estás utilizando Windows, vaya a Todos los programas o Programas y, a continuación, seleccione la carpeta de programa de la impresora de la> lista de la carpeta de la impresora, haga clic en Mantenimiento - Alinear cartuchos> haga clic en Imprimir> Siga las instrucciones en la pantalla del ordenador hasta el final.
Si está utilizando Macintosh, desde el escritorio del Finder, haga doble clic en la carpeta de la impresora> haga doble clic en el icono de la utilidad de la impresora> En la ficha Mantenimiento, haga clic en Limpiar inyectores de impresión. Una página se imprime, la tinta pase por los inyectores del cartucho de impresión para limpiarlos. Imprimir el documento para comprobar que la calidad de impresión ha mejorado.
Nota: Esto se traduce utilizando translate.google.com.
Jun 18, 2011 | Lexmark X2600 InkJet Printer
Deseo saber si el cartucho se puede recargar ?y cuantas veces?porfavor........
Los consumidores pueden rellenar cartuchos de tinta s? mismos con un juego, o ellos pueden tomar el cartucho a un refiller o el remanufacturer donde tinta es bombeada atr?s en el cartucho. Los informes del Mundo de computadora personal que rellenaron cartuchos tienen porcentajes de aver?as m?s altos, la impresi?n menos p?ginas que nuevos cartuchos, y demuestran m?s problemas de en-p?gina como pasar como un rayo, rizar, y el color sangran
Jan 14, 2011 | Office Equipment & Supplies
LA MÁQUINA INDICA ERROR E000805-001
1) Desconecta el poder de la impresora. 2) Quita el ladrillo/bloque negro del poder por detr?s de la m?quina. (Puede ser un malvado peque?o de sacarlo la primera vez usted lo quita.
3) Abre la cima de la impresora/multi unidad de funci?n.
4) tira Suavemente la cinta para centrar el portador de cartucho de impresora.
5) Abre o el lado de izquierda o derecha y quita el cartucho. (Depende de cu?l lado el error ocurre en, negro a la izquierda, el color a la derecha)
6) Verifica que toda la tira pl?stica que cubri? los nuevos contactos en el cartucho tiene de hecho fue quitada.
7) Toallita tanto los contactos de cartucho como impresora con una seco, hilas libertan tela.
8) Enjuga el fondo del cartucho con una h?medo, hilas libertan tela para verificar que la tinta fluye y los vistazos corrigen.
9) se Asegura de que no hay agua que queda en el cartucho.
10) Reinserta el cartucho en el portador y se asegura de que es profundizado y es insertado completamente al trasero de la ranura de portador.
11) Reinserta el ladrillo/bloque del poder.
12) Conecta de nuevo el cable de energ?a el?ctrica de impresora.
13) el Poder en la impresora y el error debe ser resuelto.
14) Corre la alineaci?n de impresi?n e impresi?n o copia varias p?ginas para asegurar el problema ha sido resuelto.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Dec 19, 2010 | Office Equipment & Supplies
Tenemos una t160 y en el visor da el siguiente error "32 cartucho no soportado" pero tampoco se puede acceder al menu propio del equipo.¿Cuales serían los pasos a seguir para...
reviza que que sea el cartucho correcto
trata de quitar todos los cartuchos y encenderl a impresora sin los cartruchos instalados
instala los cartuchos de nuevo
si no funciona prueba los mismos pasos pero al encender de nuevo la impresora deja precionado el boton de encendido por 30 sec o mas para hacerle un RESET al sistema
SALUDOS!!!!!
Aug 11, 2010 | Lexmark Optra T610 Laser Printer
HP C7280 All in One Printer: Ongoing error to change ink
Hola. Si el cartucho es nuevo, devuelvelo, es el cartucho que esta defectuoso.
Pero si es cartucho ha sido recargado lee las siguientes lineas:
Tienes que decirme si los cartuchos was refilled, porque en ese caso la impresora no los va a reconocer como llenos., la razon es porque los cartuchos tienen un "contador electronic" que solo analiza informacion de cuantas hojas se han impreso, y al momento de ser recargados solo les colocan tinta, y el contador sigue marcando vacio.
Si aun con este mensaje puedes seguir imprimiendo, no te preocupes, pero si no, por favor dejame saber el modelo de tus cartuchos como respuesta y te mostrare como resetear.
Apr 04, 2010 | HP PSC 2175 All-In-One InkJet Printer
Me da un error 5C00
Ola!
Si usted tiene que el muchos error brillante enciende o los problemas eléctricos entonces es probable que sea eléctrico.
¿Sin embargo, si gusta la mayoría... y su copiadora simplemente ha quedado sin usar durante algún tiempo?
¿Entonces con tal de que funcionó OK antes de un período de non-uso? Usted apenas necesita usar un IMPRESIóN CABEZA LIMPIEZA EQUIPO para desatascar los motores de reacción diminutos.
¡Un Equipo de Rubor Chorro de tinta Mágico normalmente trabaja un obsequio en aquéllos!
La Magica es ideal para el unclogging los motores de reacción diminutos en cualquier Canon, Epson HP y quitando esas líneas blancas horribles que normalmente aparecen en las impresiones cuando secó la tinta estorba varios motores de reacción...
¿Así si el suyo aparece una traba para ser? todos que usted debe necesitar hacer son usar el equipo de Rubor Chorro de tinta Mágico para empapar la cabeza de la impresión y usted debe estar imprimiendo de nuevo gusta nuevo.
Usted se cubre atrás por un 30 dinero del día la garantía si no.
¡La Suerte buena!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Aug 08, 2009 | Canon PIXMA iP90 Mobile Printer
LEXMARK X3550
Quite los cartuchos. y asegúrese que las pequeñas cintas protectoras han sido quitadas de los contactos. Entonces examine donde los cartuchos caben en la impresora. ¿Es limpio en allí? ¿Hay allí alguna tinta secada o gotas de la tinta en allí? Si hay, usted puede apagar y desenchufar la impresora y usar una cantidad diminuta del alcohol desinfectante en un Qtip para limpiar la tinta.
Si no sustituyen los cartuchos que se los aseguran adecuado cómodamente. Ahora continúes su computadora a - Principio> Panel de instrumentos> impresoras y faxes> chasquido DERECHO en su icono de impresora y elija preferencias> servicios. Cuando usted está en servicios abiertos y mira cada opción allí. Haga cualquier prueba o limpieza de los cartuchos a los cuales esto le pregunta. Cuando usted es terminado, apaga su impresora y reanuda su computadora. Si el problema no es ido, contestarme. Espero que mi español sea comprensible. Gracias.
Aug 19, 2008 | Lexmark X3550 All-In-One Printer
Red light flasing
si miras donde va el cartucho, ves un alambre (metal) al lado derecho? Ves que este alambre esta medio suelto? ves que este alambre a dañado el cable de atras? el que lleva las señales del cartucho la impresora?
bueno e pregunto todo esto porque me ha pasado a mi. Este metal se ha suelto en los dos (color y negro) y me ha dañado los dos cables de atras. ahora la impresora no ve si hay cartuchos o no.
puede que este sea tu problem.
Escribeme y me dejas saber si este es tu problema queria llamar a HP para decirles que tienen un producto con problemas y ver como resuelvo el remplazar la impresora
ngr7000@hotmail.com
Rafael
Jun 30, 2008 | HP DeskJet 9800 InkJet Printer
Pixma MP160 not faxing
ERROR E27
Hola gente no lo consigo ni por un lado ni por otro.
Alguien lo ha conseguido ???
Sigo las instrucciones al pie de la letra:
Describo las teclas que he usado:
parar -> tecla en roja que tiene un circulo y dentro un triangulo
on/off -> tecla que pone on/off arriba
1- Pulso y mantengo pulsá la tecla de parar
2- pulso y mantengo "on/off" y suelto parar
3- teniendo pulsada "on/off" pulso dos veces para y en la segunda suelto para y on/off
4- la impresora se enciende y pone un cero en el contador
5- pulso una vez la tecla parar se enciendo la luz de la izquierda que es naranja la que esta con el triangulo y un rayo dentro
6- pulso otra vez para y la luz se va a on/off
7- pulso para otra vez la luz pa la izquierda es decir triangulo y rayo
8- pulso otra vez para (ya van 4 veces) y la luz pasa a on/off
y ahora que....
por que yo pulso ahora on/off y la impresora hace ruido pero la apago la vuelvo a encender y las luces de falta de tinta, es decir la de la B y la C siguen encendida
no se que hacer he mirao por todos los foros del mundo estoy a punto de tirarla por la ventana y comprarme otra
saludos
Apr 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
1,187 people viewed this question
k24674
jasbo
jasbo
