Does the white lead on the flyback transformer on the Mitsubishi wt-46807 TV pull out of the flyback transformer to remove the chassis? I can't seem to get the wire out and I don't want to force it without knowing whether or not it is suppose to unplug.
-   I HAVE A 36in.PANASONIC AND I WAN'T TO REMOVE THE MAIN BOARD HOW DOES THE FAT BLACK CABLE FROM THE FLYBACK TRANS. COME LOSE ? AT THE TRANS. END OR THE OTHER END.-   GTMDRT
Dec 10, 2007
-   How do I remove the wires from the flyback transformer to remove the chassis? It has two red wires, one thicker then the other. It's in a Sony KP-48V80.-   juve
all the projection tv are made with removal chassis in mind becouse thats the only parts you carry to the shop remove the upper ruber tap and gentely but firme pull the cable..be carefull tvs have verry dangerous sites, specialy in that area..good luck
to remove the high voltage lead from the fly back on that set , you must grasp the lead at the base and push down and counter-clockwise 1/4 turn and the lead should be free..
Was this helpful?
Yes
No
Solution #5
posted on Mar 15, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Don't pull the wire from the flyback. Remove it from the other end. It should come out with very little effort.
For issue http://www.fixya.com/support/t3427713-rgb_each_side_hard_time_lining_up SD Tech says he...
(More)
For issue http://www.fixya.com/support/t3427713-rgb_each_side_hard_time_lining_up SD Tech says he has step by step instructions, how do I get them?
When I power up set it clicks on and then within seconds powers down... just happened. Was working...
(More)
When I power up set it clicks on and then within seconds powers down... just happened. Was working fine.
my mitsubishi wt46807 won't turn on. When you push the power button, the green light comes on for...
(More)
my mitsubishi wt46807 won't turn on. When you push the power button, the green light comes on for about 3 seconds then turns off. this is the second mitsubishi WT that this happens to.
