Question about Panasonic Toughbook 72 Notebook
Toughbook CF-18 won't start-up after adding RAM
I have a panasonic toughbook CF-18B, wich comes with a standard 256 RAM-memory. Yesterday I added 512 extra RAM and now nothing happens anymore when I turn on the computer. No lights at all! Is it possible I blew a fuse? And if so; can this be replaced?
Many thanks in advance!
1) Remove the ram module you installed (with laptop turned off) then power on laptop.
If it laptop powers one, then either A)Your new ram chip is not compatible with your laptop (read your owners manual for the "exact" type of ram you need.) or search eBay "panasonic cf-18 ram" for example. 1 Gig ram was $32 when I just checked...
If laptop does NOT power on after you remove the new chip, then you may have accidentally fried your motherboard when installing it. Not likely, but possible. Human body can generate a lot of static electricity, if you do not "ground" yourself you can easily fry an electronic component / motherboard, etc... see this link below. If this is the case have a technician give you an estimate on repair.
http://www.wikihow.com/Ground-Yourself-to-Avoid-Destroying-a-Computer-with-Electrostatic-Discharge
Good luck !
Posted on Jan 19, 2009
  • yeti747
    yeti747 Nov 22, 2013
    Hi, it might be that the RAMs simply did no jump right into their sockets.This happens a lot if you are a newbie. usually rams are easy to remove and to add, if you use force or sth. works hard, you did not use the ram clips well. Try agai, it should work easy and without use of force, in my benq laptop rams will jump out to the top once i open the clip so iI just put the new ram on top of the clips and press it down
  • 3 Answers
There could be several problems with what you have done with your laptop. One of the problems which I have seen alot happen when changing ram in a laptop is you have gone over the limit of what the laptop can handle. Have you tried putting your old ram back in. If not try putting your old ram back in and see if the laptop boots up. If not then unplug your laptop and take the battery out and hold the power button down until the count of 10 mississippi which will drain the onboard power supply allowing you to reset the mother board. Did you ground yourself while working inside the laptop. If your body had any static charge to it while working inside the laptop you might have shocked the hardrive or one of the other vital parts inside. Also check your work to see that you didn't accidently knock a wire connection loose while working inside since laptops do not have alot of room to work this happens alot also.
Posted on Oct 23, 2008
4 Suggested Answers
asish_shrm
  • 121 Answers
SOURCE: no sound cf 48
download Astra software...run it on your computer.....you will get information of all devices through this software.....check the chip set manufacturer and the number for the chip set do a google search for that particular audio driver chip set you will be good to go
Posted on Nov 10, 2008
SOURCE: Panasonic CF-51 Toughbook Fn keys don't work at all
The following website contains the needed drivers:
https://eww.pavc.panasonic.co.jp/pc/cgi-bin/itn/toughbook/dl01.cgi
Select your model of CF-51 Toughbook, but you MUST be specific. There are about nine variations of the CF-51 so you must use the right drivers.
Download the hkeyapp, hkeyset, and hotkey files and unpack all files. Use the default unpack locations. If you download the files for a laptop version that is not your own, when you try to run any of these files the computer will tell you that the file is not for your model. If the files successfully unpack then you know you have the right files.
For hkeyset and hkeyapp you must run the set-up applications in the unpacked folders.
Go to Control Panel>System>Hardware>Device Manager and go to Other Devices.
The Hotkeys will appear as an "Unknown Devices" so if there is more than one, right click and choose "Update Driver".
Select "Install driver from specific location" and direct it to "C:\util2\drivers\hotkey" folder.
The computer will find the file and install the driver after which point you must restart the computer.
Hope this helps. It took me a while to figure this stuff out on my own so hope it speeds up somebody else's attempt.
Andrew
Posted on Dec 25, 2008
Borbz
  • 71 Answers
SOURCE: Installed Windows 7 on Panasonic Toughbook CF-51
..install an audio driver, it is found on the DVD package..
Posted on Feb 19, 2011
Where is the memory slots for the Panasonic CF-T8. I know about the one on the back where it the other slot?
According to Panasonic's Toughbook CFT8
owners manual there is only one slot where
you can add extra RAM. The other memory
is "non-removable" and probably soldered
directly to the motherboard.
I double checked on the Kingston RAM Website:
Bank Schema: 1GB Standard:
[1GB] (Non-Removable)
or
3GB Standard:
or
2GB Standard:
[2GB] (Non-Removable)
or
3GB Standard:
Sorry to disappoint you but that is how they
made the CFT8 Toughbook.
If it is any consolation, the CFC1 and CFC2 both have
two (2) slots on the underside of the unit. Not the CFT8.
Good Luck,
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jan 17, 2014 | Panasonic Toughbook Cf-t8 Win7 Core2 Duo...
How do I increase the RAM on CF-29 to 1536? I am unable to locate any 1536 cards and it only has one slot. It seems all that is offered is 512 -- and the machines already have 512..... Thanks
Memory sticks come in either 128, 512, or 1024 megabytes. Since you already have 512 and you only have one slot available, you'll want a 1024 stick. These sticks will be marked as 1x1024 MB, or 1 GB.
Mar 04, 2011 | Panasonic Toughbook CF-29 Notebook
The panasonicCF-73 tough book I am using has 256 RAM, can I increase this to 1gb or 2gb? Thank you,
According to: http://www.upgradecomputermemory.com/ram.cfm/memory/P/Panasonic/Toughbook-Series/Toughbook-73-CF-73
your CF-73 has "integrated" 256MB of memory, and supports a maximum addition of 1GB of RAM.
The web-site says about $33, which _definitely_ is a good investment to speed-up your computer.
Jan 23, 2011 | Panasonic Toughbook CF-73 Notebook
Can I install windows 7 on a panasonic toughbook cf-18 tablet
I don't thank they have it out for tablet yet. Wait a bit and they should.
Nov 11, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic cf 18b toughbook,touch screen do not work,help
goto your device manager and then find your display driver and update it. Dont search for it, manually locate the driver being in the location where you extracted the driver. Then update. and bingo!
Feb 18, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Need a memory module for toughbook cf-18bhazxft
You can go to a website like kingston.com; crucial.com; tigerdirect.com; newegg.com & use their memory finders to find out what type of RAM your computer uses & what they have available for purchase. Hope this helps & please rate this solution as fixya. Thanks.
Feb 03, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Cf-18 toughbook
The BIOS may not support the larger drive at all; I suggest you look for a Toughbook forum and repost there and check Panasonic's site for a manual download and possibly a BIOS upgrade if the unit is equipped with a flash BIOS.
Aug 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Which one?
It uses DDR PC2700 memory.
Feb 11, 2008 | Panasonic Toughbook CF-73 Notebook
Panasonic Toughbook 72 Notebook Logo
1,014 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
