Question about LaCie Ethernet Disk (300788) 1000 GB Network Hard Drive
Lost connection while coping files to Lacie ED Mini
I had problem when I tried to copy files to the drive. I got ‘Error Copying File or Folder’ message saying ‘Cannot copy 100_1287 the request could not be performed because of an I/O device error’, then I could not access the drive and got another error message ‘… is not accessible. You might not have permission to use this network resource. Contact admin of this server to find out if you have access permissions. The request could not be performed because of I/O device error.’
I don’t know if this is something to do with the size, it seems like small files can be done easily.
Please help.
Ke
  • topcat7736 Mar 19, 2017
    Hi ke92, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Is your computer connected to the router wirelessly or via Ethernet cable?
sandrew
  • 2961 Answers
SOURCE: Change permissions for external Hard Drive on Mac OS X
You should be able to change the permissions, if you Right click on the drive and go to properties and click on the sharing tab and click permissions. apologies if you have already tried this.
Posted on Feb 01, 2007
SOURCE: permissions of access
No.
Posted on Oct 06, 2007
SOURCE: Lacie Ethernet disk mini 500 Gb
I had exactly the same problem, no access to the windows media server - the no space message - and all my users missing from the user tab.
Following up from gogogo123's comment, we simply cleared the log and it was fine. I can only assume that there is an internal file size limit on the log file, and if it can't write your actions to the log then it doesn't do them!
Posted on Mar 24, 2008
SOURCE: external hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Posted on Sep 08, 2008
iklln6
  • 35 Answers
SOURCE: Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Posted on Jul 15, 2009
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Coping file from external hard disk to hard disk his error "internal error 0000000B.
This seems to happen mostly when anti-virus programs are taking too long to scan a file, or have frozen while scanning the files you are trying to copy. Try temporary disabling the virus scanner while copying the files.
Mar 28, 2011 | Computers & Internet
Copied files to a folder on portable harddrive
1. Try creating another folder and coping the content from the original to the new folder on the USB drive.
You may have stopped the coping process inadvertently during the copy process.
Apr 07, 2010 | Toshiba 120GB USB 2.0 Portable External...
Error copying file or folder c annot copy xxxxx
try copying the file into a folder with different name
Mar 05, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
Everytime i copy files into the lacie 2T big disk extreme it gives me an error after uploading that says can't copy file because is been "used". I have reformat it but still gives me the problem. What...
It may sound unrelated but there are maybe two things to check first
1. If the drive or folder you are copying from is "shared" then this could quite conceivably cause the problem. Check and turn off the share or move COPY the file to a non shared location first.
2. Unwanted programs eg. virus / malware / spyware can also cause these types of issue. NOTE there is a great difference between virus and spyware and they both need special programs to deal with this area.
Aug 16, 2009 | LaCie 301294U 1TB Big Disk Extreme + with...
Copying pictures from computer to memory card
vista is main problem are you viewing the picture before you move them vista has problem if u open it 1st before coping moving etc etc it does what u mentiond b4 either shut the program u are using to view with down before u transfer them
Dec 02, 2008 | Cameras
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Drive Full After Backing-Up Just Under 4gb of Files
Are you trying to create one giant zip file or something similar? It sounds as if your Lacie 250gb hard drive has been formatted with a FAT32 filesystem and you are running into the maximum file size limit of 4gb minus 1 byte. Try just copying your files without using any compression utility or try reformatting your Lacie 250gb hard drive with the NTFS filesystem instead.
Feb 07, 2008 | LaCie (300728U) 250 GB Hard Drive
Coping dvds ,cds
If you are copying a DVD to another blank DVD, just put the original DVD inside > open Nero > click Copy disk > then the copy dialog box window will appear. > Just select your favourite speed ( [8x] medium speed recommended) and click Burn. If you are copying a DVD to your hard disk, just put your DVD on the drive, Open My computer > right click DVD drive icon and click open > Then select the appropriate file or folder to copy > right click it select copy > close the window. Now open My computer > open disk drive [may be D: or E:and so on... ] > right click and select paste. Now the file will be copied to your disk.
Sep 29, 2007 | Ahead Software Nero 6.0 (60045) for PC
LaCie Ethernet Disk (300788) 1000 GB Network Hard Drive Logo
463 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
