Question about KitchenAid Refrigerators
I have a KA side by side KSRS27ILSS03 and the ice maker won't discharge the ice it has already made and has stopped producing. The red light on the side blinks twice periodically when the door is
ttech
  • 139 Answers
SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
I Have a Solution for this Problem,Contact live on line Now ttech
Posted on Jul 21, 2007
fridgetech
  • 473 Answers
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Posted on Nov 07, 2007
peyton32034
  • 410 Answers
SOURCE: Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Posted on Jan 07, 2008
Krazytech
  • 725 Answers
SOURCE: Ice maker
is the it turned on and the bail arm down?
Posted on Sep 07, 2008
aborcass
  • 2651 Answers
SOURCE: Ice maker only produces crushed ice
not really a reset button but htere is a solenoid that controls the type of ice coming out of dispenser. with the ice bucket in place give a look at it from underneath and find the brass rod spanning from front to back of bucket. that rod hooks into a solenoid catch that when activated lifts the rod up and down for crushed/ or cubed ice.. after locating the "hole" in which the rod enters you should also see a corresponding plastic ring that would catch the rod upn activating stich and pull/up and down.. Ill assume that the "catch ring" is tuck in the up positon , might only be frozen up in which case you can hit it with a hair dryer to melt it, its also possible that the \solenoid had melted it self in the up position in which case you need to replace it.. to check this theory you can hook the brass rod into the ring assy in which case youll only dispense cubed no crushed
Posted on Nov 03, 2008
Fgh82844lf4
Hello nassaupc - If the unit has stopped making ice completely, try checking the following steps.
· It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there\'s no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
· Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won\'t cycle properly.
· When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
· Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you\'ve found broken parts, you can just replace it.
Should these suggestions prove to be ineffective, contact with a professional to accurately pinpoint any potentially more serious issues.
Jan 14, 2013 | Frigidaire FRT21P5A Top Freezer...
Frigidaire side by side water line clog
Hi -I understand that your unit is still not producing any ice or dispensing water. Some of the following steps you have already confirmed. I suggest confirmed the steps below and see if any is helpful :
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 10, 2012 | Refrigerators
Icemaker stopped working
Hello varjr - If your ice maker has stopped producing ice completely, try checking the following:
Should this suggestion prove to be ineffective contact a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FRS26R4A Side by Side...
Ice maker not working
Oct 08, 2012 | Frigidaire FRS23W3A Side by Side...
Dishwasher leaking at bottom of door
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
Oct 03, 2012 | Frigidaire Dishwashers
Frigidaire plhs3teesbe model won't make ice
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not making ice
Hi - If your ice maker has stopped producing ice completely, try checking the following:
Oct 01, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire french door refrigerator not making ice
Hello jcwilson2929 - If your ice maker has stopped producing ice completely, you can check the following:
Sep 26, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Electrolux icemaker not working
If your ice maker has stopped producing ice completely, please check these, in this order:
Should these suggestions prove to be ineffective, contact a professional to diagnose the unit.
Sep 13, 2012 | Electrolux Refrigerators
I bought a ice cream maker from the US unfortuneatly the drive assembley isn't the right fit for my kitchenaid. Do you or can you help me find the right part? Kind regards Robyn Ricketts
Hi ROBYN, Happy New Year! First a couple of clarification questions: A) Was your ice-cream maker a Kitchenaid (KA) Ice Cream maker, too, and B) was your mixer purchased after 1990? If you purchased a KA Ice Cream maker and your mixer is less than 20 years old, according to KA, the Ice cream maker should fit all mixer produced after 1990.
If you have a different brand (not KA) of ice cream maker, then I’m afraid you just won’t just be able to replace the drive assembly, but you will also need the correct dasher (the scraper inside the freeze bowl), as such you probably would be better off purchasing a KA Ice Cream Maker, which would be compatible with your mixer. Of course if your mixer is over 20 years old, then even if you have a KA Ice Cream maker, it may not fit correctly anyway, which leaves you in a conundrum. Should you purchase a new KA mixer for your KA Ice Cream maker or do you purchase a new KA Ice Cream Maker to go with your current KA mixer produced after 1990?
You can download the KA Ice Cream Maker Use & Care Manual from the KA website at: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KICA0WH_Use%20and%20Care_EN.pdf
I wish I could offer you a better solution to use your new ice cream maker with your current mixer, but unfortunately I am unable to do so.
I hope this was helpful, even if it doesn’t provide you the answer you were looking for. Good Luck, Howard, Burke, VA. If this solution was helpful though, please rate it. hslincoln
Jan 10, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
