Question about Fuji FinePix F455 Digital Camera
Blurred view in window, not auto focussing
When mt f44 is switched on the view finder is blurred. I have tried pushing down on the button to auto focus but that still doesn't put the shot into focus. The only way to get the camera to focus is to zoom in. I have re-set the camera several times but this has not stopped the problem. Jessops seem to think there is a fault with the lense?
  • 4 Answers
SOURCE: Blurred Pictures
1. What is the focal length of lens you are using? 2. Is the blur occurring with lens with a lower focal length than the telelens? 3. Do you still get a blur when you use the telelens with a tripod or a firm base? Regards Raman
Posted on Oct 01, 2007
dg9dotorg
  • 151 Answers
SOURCE: When Zooming picture it produces blurred or fuzzy picture
This is when zooming through your camera LCD I presume? For small screens usually banding and pixelation is common, if this happens also when the picture is zoomed in on a larger monitor like on your computer then the resolution you set for your camera is low. You can check for the camera setting and increase the resolution from for example 1024x768 to a much higher value and the fuzinnes (blur) will disappear altogether...
Posted on Feb 08, 2008
pauman
  • 248 Answers
SOURCE: Blurred subjects
Fuji uses a 16MB xD card with the camera, which won't hold too many 4 Megapixel photos at the highest quality setting. So you should plan on buying a larger card right away. xD cards are currently available as large as 1GB, and I think 128MB is a good starter size for most people. Be warned that xD cards tend to be more expensive than CompactFlash and SD cards.
Posted on Jun 19, 2008
  • 196 Answers
SOURCE: blurred picture
either there is dust on the lens internally or there is a battery problem.
check out this.
thanks.
Posted on Nov 05, 2008
Steve5
  • 423 Answers
SOURCE: focus problem
It sounds like the eyepiece focus adjustment knob may just need to be set for your eyesight. There should be a small knob or dial with a + & - sign around it. This is the "diopter" which doesn't affect the camera's focusing, only how you see the image.
Posted on Mar 16, 2009
Every picture i take of still objects turn out really blurred
How do you hold your camera? Holding it at arms length and viewing the subject through the screen will practically guarantee a blurred image with most cameras. You might get away with it with cameras equipped with Image Stabilization but not compact digitals.
Use the view finder and hold camera firmly against your face. Frame your subject, take a breath in then exhale, stop breathing momentarily and squeeze the button. (Don't forget to start breathing again!) If possible rest your camera on or against a solid object while shooting.
May 18, 2011 | Cameras
I cannot figure put how to correct a blurred image before shooting the pic Help?
Hold the shutter button down half way to automatically adjust the focus.
You should hear a tone and/or see an icon on the screen to tell you it is focussed.
Also, read the instruction manual!
Regards Robyn
Jan 07, 2011 | Cameras
PROBLEM WITH LENS/ LCD SCREEN
problem with the lens,not with the lcd,the image fomation is bad,so replace the C.C.D
Mar 05, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
Picture is blurred and sound is perfect.
dont know if its the same model as mine but mine has a small sliding focus switch underneath the view finder if you tilt the viewfinder up you may find it it may look like the clip that locks the viewer down but it slides side to side .regards norman
Nov 22, 2008 | Samsung VP-D10 Mini DV Digital Camcorder
Nikon D40 will not focus
on the right side of the view finder there is a little bar. Make sure it is all the way down. If it is in the up position then it will make the viewfinder, shouldn't make the images blurry though. Also make sure it is in AF not MF (auto focus and manual focus).
Oct 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Samsung Digital camcoder VP-D305i : LCD image blurred
did you ever find a solution to this problem ?
Jun 02, 2008 | Video Cameras
View finder in samsung VP- W90 very blurred. Focus not the problem.
If the focus is blurred on the view finder, assuming you are talking about the eye piece and not the lcd, then it is a out of focus issue. Even though when you view it it's ok. Some cameras still have a focus knob somewhere to focus the eye piece.
May 27, 2008 | Samsung Cameras
Not Focussing
sir,i think this is not focusing problum, u see any optic mois or finger prints ?u first clean this
Mar 04, 2008 | Olympus Camedia D-425 / C-170 Digital...
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Blurred Picture in the shooting mode
one of the possible cause of the said problem can be a defective or broken flex ribbion cable carrying signal to the focus motor. the replacement of the flex will solve the problem. othe may be friction in the focus assembly. cleaning of the same will do the job. but in both the cases you will need the help of repair shop.
Sep 13, 2006 | Canon PowerShot A75 Digital Camera
Fuji FinePix F455 Digital Camera Logo
44 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
