In your case you need to clean the color wheel and laser is probably covered in dust and other contaminants this is not that hard to do just use the access panel and a microfiber rag a can of dry air would help. also I'm including a video to better help you I did not have as hard a time cleaning mine it had an access panel I used long q tips to clean mine and a microfiber rage to clean the lamp I also cleaned the large projection mirror it took me about an hour to do it all...........I hope this helps
here is video 1 of 5 he has all the others on his site as well
There is only one brightness bulb for your tv. You have the main bulbs which run the color for the Tv and then you have another bulb which runs the brighness. Typically it is a flourecent bulb inside which does need replacement now and then. Check tje specks on the tv's web site and you should be able to get the model number of the bulb from them and you should be able to purchase it from a repair shop or from online
I have the same problem,...
would any one know where to buy the bulb mentioned above within the u.k , and how much does it cost? (have been told its much cheaper pickin one up in france..?
