Question about ASUS Eee PC Seashell 1005PEMU27WT 101Inch White Netbook with Kindle for PC (11 Hours of Battery
Usb device over current status detected problem
nai6378
  • 58 Answers
SOURCE: cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
Posted on May 11, 2008
  • 42 Answers
SOURCE: system shutdown in 15 seconds
hi, pl check for viruses, scan the system, and go to cmd prompt and issue this commnd at c:\ shudown -a and press enter to disable reboot and scan the system and check any hardware issue.
Posted on Aug 12, 2008
Benimur
  • 6966 Answers
SOURCE: CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
  • 503 Answers
SOURCE: System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
Posted on May 31, 2010
  • 11800 Answers
SOURCE: Asus P5RD-2-UM acpi bios revision
no keyboard detected. fatal error... system halted = your keyboard is dead, replace it. If you get the same message after a new keyboard then the PS2 connector is dead, you will have to use an USB keyboard.
Posted on Dec 20, 2010
When i start my pc i get the error "please enter
One or more of your USB devices connected to your PC are malfunctioned, remove any usb connection exept keyboard and mouse. Boot the PC , if the error still exists then reboot after removing your Mouse first and keyboard at second. Tell me what happens after these.
Sep 14, 2011 | ASUS P5KPL-AM SE Motherboard
I would plug your device into a powered hub as it seems to be taking more power than your computer can deliver.
Powered hubs are very innexpensive. Check on ebay, I did and pair less than £5 for one that gave me 7 outlets and up to 5 Amps, including postage!
Feb 04, 2011 | Computers & Internet
USB Over Current Status Detected, Computer will shut down in 15 seconds
this message popped up because one of the device which you connected to the usb of the pc was overdrawing current i.e more than 5V DC. Hence, the built in system security gave this message and will shut down your computer in 15 seconds. In order to avoid this message first remove all the usb items connected to it and then connect one by one and detect the faulty one and replace.
Jan 29, 2011 | ASUS P5PE-VM Motherboard
Acer P5Q-EM mobo. When trying to boot i get this message USB DEVICE OVER CURRENT STATUS DETECTED WILL SWHUT DOWN IN 15 sec. which it does, I am also unable to get into the bios, even before I get the...
Ive seen this a few times. Its either a usb device plugged into the board shorting a usb port out, or whoever put it together wired the usb ports wrong on the board. FYI its an Asus mb not an Acer.
Sep 07, 2010 | Acer Computers & Internet
When the computer is booting these words appears usb device over current status detected, and then after 15 seconds the computer is shut down
A USB device is drawing too much power so the system crashes. Remove all devices attached to USB and try again. If it's the same then remove all external USB ports - the ones connected with wires to the motherboard. If it's the same then there's a short in the motherboard - unfixable, replace it with a new one.
Jul 10, 2010 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Usb device over current status detected shotdown in 15 second. cant acces the bios
Pull the little battery on the motherboard, and unplug the PC, let it sit for a minute or so. Put the battery back in and turn it on, BIOS should be reset.
Oct 01, 2009 | ASUS P5PE-VM Motherboard
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
Nov 11, 2008 | ASUS P5PE-VM Motherboard
ASUS Eee PC Seashell 1005PEMU27WT 101Inch White Netbook with Kindle for PC (11 Hours of Battery Logo
234 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
