Question about Electrolux Washing Machines
E10 error message on zanussi electrolux washer dryer , why is this?
  • 3 Answers
SOURCE: ZANUSSI ZJD12191 WASHER/DRYER
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
Posted on Jul 19, 2008
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Posted on Jul 22, 2008
  • 25 Answers
SOURCE: e10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Posted on Feb 28, 2009
SOURCE: My aeg lavamat 16810 washer dryer won't dry. The
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Posted on Nov 11, 2009
SOURCE: e10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Posted on Feb 21, 2010
My washing machine keeps stopping during its washing cycle and says fault E10
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
Dec 21, 2014 | Electrolux Washing Machines
Kenmore front load washer, model 417
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 15, 2009 | Kenmore Washing Machines
ZANUSSI FJR1454 W WASHING MACHINE E10 ERROR . IT TAKES NEARLY THREE HOURS TO DO A QUICK WASH. IT BLEEPS AT LEAST 4 OR 5 TIMES THROUGHOUT A WASH CYCLE AND THE CYCLE COUNTER DOESNT SEEM TO COUNT DOWN...
Oct 10, 2009 | Washing Machines
Displaying error 10 , door won't open
Sep 07, 2009 | Kenmore Washing Machines
I am constantly getting a E10 error on my Zanussi w1042w. what could be causing this?
Jul 14, 2009 | Washing Machines
My Fridgidaire front load clothes washer model ltf2940es3 is showing error message e10
May 03, 2009 | Washing Machines
E10 code on a zanussi jet system washer
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
DRYER NOT WORKING
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
E10 error code
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
