Question about Sony Ericsson Mobile Bluetooth Car Kit HCB-700 works with any Bluetooth phones that support the Head... Headset
China Mobile N73 LOW SIGNAL PROBLEM
I have been getting low signal problem.. also when i speaking with my friends its got call ends itself. And more often its shows "Emergency".
Could u please Help me ASAP..
Hi there, I have been getting low signal problem.. also when i speaking with my friends its got call ends itself. And more often its shows "Emergency". Could u please Help me ASAP
Posted on Nov 22, 2008
Low signal n73
its not nessessarely your phone could also be the signal around you
Sep 26, 2013 | Nokia N72 Cellular Phone
Code B0100
Hi there:
DTC B0100 - Electronic Front End Sensor 1 Performance
The following can cause an intermittent condition:
  • A short between the front end sensor signal and low reference circuits
  • High or low resistance in the front end sensor signal and low reference circuits
  • Inspect the front end sensor signal and low reference circuits carefully for cutting and/or chafing
  • Verify that the correct front end sensor is installed in the vehicle
Hope helps.
Jun 03, 2013 | 2006 Pontiac Torrent
My mobile is Nokia N73. I recently came to the US. When I was in India I never had signal problem in my mobile. Now I use AT&T connection. Right after using this connection, I am facing no signal...
Please check with the service provider in your area for the GSM frequency and if this is supported. Also make sure that the area you are residing covers this or the building within is shielding the signal.
Try to use your SIM witth another phone to confirm on this or check with a friend who has the same network connection.
If the SIM works well with another phone then there is some issues with the phone, check for moisture within or problems in the RF network circuit.
Sep 20, 2011 | Cell Phones
I have had a LinkSys WAP54G wireless router for 1 month The signal strength has always indicated very low. Is there anything I should /could do to improve this. Interestingly the other wireless...
HI, If its a Internet link which u are speaking about, Please connect the LAN to the System with LAN wire and check the speed. the Problem will be due to low connectivity issue. Wireless router will not increase the bandwidth, it can able to provide the same or below the bandwidth which it received from the ISP.
Mar 01, 2011 | Linksys WAP54G (WAP54G-UK) 802.11b/g...
My nokia N73 mobile phone getting low battery fast. after charging the battery the battery power remains only up to maximum of 2-3 hours. i brought a new original battery to check whether its a defect of...
This is a very common problem with the nokia N73 phone,
The problem you are experiencing with your phone is not from the battery but rather from the panel of your phone,
The panel of your phone is corrupted,hence its irrationally discharging the battery rather than storing up the charge.
The solution is to ;
1.take apart the phone,
2.Conduct a thorough cleaning and servicing of the phone panel.
3.If problem persists,it means the panel of your phone is gone and needs a replacement.
Best of luck!!
Aug 13, 2010 | Nokia N73 Cellular Phone
Nokia N73 signal problems
network is dmaged go to mobile phone repaier place and fix it will cost 30 to $40
Apr 16, 2010 | Nokia N73 Music Edition Smartphone
My battery signal shows full and after sometime shows battery low
check if ur battery has swollen...this happens due to repetive over charging...d capacitors burn out...if tats d case...replace ur battery immediately..since d old 1 has chances of bursting...
if thats not d case thn try another battery,,,prob persists thn itz a s/w error goto a nokia care...they'll do it 4 free
Oct 28, 2009 | Nokia N73 Cellular Phone
Low output signal on receiver 2 output
Hi jimreeves46 sense your getting a low signal on TV2 whatyou will need to do is a Hard Reset and Check Switch Test. The first thing wewill do is the Hard Reset, you will want to unplug the receiver for 10 secondsand plug it back in and it will power back up by itself. After it fully resetsyou will need to do a Check Switch Test, you will need to press the MENU buttonand then the numbers 6-1-1 on the remote. You will need to select Check Switchand then test. After the test completes exit out of all Menus then it will reacquirethe signal and you will have a stronger signal for TV 2.
Mike Houston of DISH Network
Aug 21, 2009 | DISH Network 322 DTV Receiver
Nokia n73
go to iunlock.com for the repair of ur dead nokia n73.
u can do the by mailing ur phone to iunlock.
nadeem
Oct 25, 2008 | Nokia N73 Cellular Phone
Low volume and problems with squelch
Check your speaker for a short.
Jul 06, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
500 people viewed this question
Top Sony Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
basssplayer
Level 1 Expert
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
