Question about Akai MPC-4000 Plus Production Center (w/80 GB Hard Drive&Onboard Sounds)
Akai mpc 4000 - hard drive & cd rom not found by machine
The hard drive & cd rom both have power connected but are not showing as devices in the menu. Thought that it may be that the hard drive was not set to master but this is not the problem.
  • Frank
    Frank May 11, 2010
    mmmmmmmmmm. did you try to go into the BIOS and see if the machine sees the hardware????
4 Suggested Answers
SOURCE: Akai MPC 4000 Plus
You could set the sample to "one shot" in the trim page or in the Program>KG Mix>Zone page.... it is currently set to "as sample"... i like to use the release to let the sample fade out as long as i like... its a lot diffrent from the old poly mono thing but i like it better overall... hope this is helpfull.
Posted on Apr 22, 2008
SOURCE: Mpc 4000 lcd
Did you check the orietation of the ribbon connecter?
Posted on May 11, 2008
SOURCE: akai mpc 4000
Can I install a hard drive and eliminate having to insert a flash memory card to upload files from my mac?
Posted on Dec 13, 2008
  • 146 Answers
SOURCE: my mpc hard drive freezes
Sounds like the hard drive either has bad sectors or has corrupted data and it needs to be formatted.
If checking for errors or formatting doesn't help, you may need to replace the drive. Depending on the hard drive that is installed, it may be getting to the end of useable life cycle or has damaged sectors and causes the MPC to lock up. It may also be that the controller board on the drive is failing.
Check the drive either with the built in utility or connect it to a computer and use a non destructive test utility like HDD Regenerator that runs from a bootable CD on a PC.
Cheers and good luck.
Posted on Dec 27, 2008
I can't hear any sounds in my mpc 4000
Have you loaded sounds for the pads from an internal or external storage device? (Such as CD or Internal Hard Drive, if installed) - each time you turn on the power, the programs are cleared so the pads will not make any noise until you load the sounds you want.
Otherwise, it could be related to your speaker setup?
Provide some details on your system setup and whether you are loading programs etc.
Nov 07, 2010 | Akai MPC-4000 Plus Production Center (w/80...
My mpc 2000 wont load the boot disk when i insert it. it just says "insert mpc2000 disk!" what should i do?
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Sep 21, 2010 | Akai MPC-4000 Plus Production Center (w/80...
When I try to load a program on the mpc 4000, the program won't show up on the main screen seq window. What's could be wrong? Thanks Dame
I have same problem, havent figure iyt out yet since 2month ago when i got my mpc4000. Can anybody help please mail martinwolfx@hotmail.com Cheers /Martin in Sweden
Sep 18, 2010 | Akai MPC-4000 Plus Production Center (w/80...
I insert my falsh drive into my mpc 1000 and i
First you must configure your PC to read your mpc 100
flush card. Just insert the software CD driver of your mpc
100 flush card, if you have the CD. Otherwise, you must
have a download from the internet for the software driver.
Nov 08, 2009 | Akai MPC-4000 Plus Production Center (w/80...
My mpc hard drive freezes
Dec 25, 2008 | Akai MPC-4000 Plus Production Center (w/80...
Akai MPC 4000 Plus
Apr 16, 2008 | Akai MPC-4000 Plus Production Center (w/80...
Akai MPC 400 Plus Drive Crash
u go to dos mode to using boot disk or ,press F8 after post screen,then select dos mode and type in dos mode as 'chkdsk'
follow onscreen instruction ,thats all ,thats ok ,restart the pc then try again ,thats working i hope
regards
prasanna
Mar 04, 2008 | Akai MPC-4000 Plus Production Center (w/80...
Akai mpc 4000
Dear fixya thank you for replaying to my e-mail about my mpc 4000 problem, and yes after pulling my hair out and further investigation i did fix the problem. i had no audio comming from one of the main outputs and all i did was change that one faulty audio cable and everything was all good. I took the no good cable, tied it in to a knot and dumped it right into the trash can. Now im back to master beatz...
Feb 16, 2008 | Akai MPC-4000 Plus Production Center (w/80...
Mpc 4000 lcd
Hey, it sounds like the LCD is not receiving any signal from the video output. I would take it somewhere to be opened up for a closer inspection. Again the cause could be something more serious on the internal circuitry. No way of telling till the schemata is tested.
Good luck
Jan 24, 2008 | Akai MPC-4000 Plus Production Center (w/80...
(Mpc 1000) Only right Channel Produces sound
Are you recording, writing, sampling in mono or stereo?
Oct 17, 2007 | Akai MPC-4000 Plus Production Center (w/80...
Computers & Internet Logo
462 people viewed this question
Top Akai Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
