Question about Archos 101 Internet Tablet
Where does a memory card go in archos 101 - Archos 101 Internet Tablet
  • 3,799 Answers
In the slot With the SD lettering next to it. It is on the left hand side of the tablet.
Posted on Feb 09, 2012
Archos 101 wont turn on
System recovery
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
To enter into the Recovery screen
- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration:
Select this and then select no to leave the recovery screen. Upon restarting, the ARCHOS will immediately start the touch-screen calibration utility.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased. "
copied from the Archos online manual
Jan 24, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
Reinstall os archos 101
how do i bring a archos 101 back to out of the box state
Aug 24, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
I try to download apps to sd card on archos 101directly but by default it downloded to internal memory. Can any one help how can i download throw sd card thank you
First, you must be on android 2.2 or higher to do this. You can download the update here: http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Next, once you have the new firmware, you go to the applications menu in settings. Once there, select a program you would like to move to the sd card and in that menu press the move to sd card button.
Apr 22, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Archos 101 internet tablet cant get out of demo mode
Try this:
Power your Archos 101 off by holding the Power Button for 10 seconds (this fully shuts it down).
While holding the Volume + button power it back up (tap power button to start up, hold volume until the tablet enters recovery mode, you'll see a series of choices instead of the demo mode).
Choose the Format System option.
When this process is complete make sure not to select Demo Mode as Android boots and the Archos 101 gets up and running.
Feb 20, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Will ethernet USB cable work with Archos 101 as it has host port ? When I spoke to technical help at Archos they said as Android will require drivers, it would may not support, unless I find the required...
Archos support is correct, if it doesn't use a simple interface like a hard drive or mouse/keyboard, then it won't work on the Archos 101.
Manufacturers aren't releasing Android drivers yet for the most part, so I wouldn't expect an ethernet to USB cable to work any time soon, sorry!
Feb 08, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Hi Just got my new archos 101 8gb Spec said 2.2 but it came with2.0.54. on plugging in to PC the upgrade didnt happen so upgraded to 2.1.04 Everything that I have thrown at it works but I dont have...
Betty,
Archos has been saying Flash would be officially available for some time now, but it's still not out. There is a beta version that I'm using, works great for me:
First step to getting Flash working is to go to your settings menu, then Applications, then check the box to allow for Unknown Sources to be installed.
To get a Beta version of Flash working use this link (from your Archos tablet):
http://ge.tt/36fA44X
You should be prompted to install this APK file on your Archos 101 after it's downloaded, this will give you a decent version of Flash (it's taken from a Droid X which has similar hardware to the Archos 101).
The Version number of your Archos 101 firmware is different from the Android Operating System. Version 2.1.8 is the latest Archos firmware as of Feb 28, 2011, this is Android 2.2.1.
To force an update, you actually need to connect the Archos 101 to the internet, not to a PC. Once you're connected to a Wifi network and have access to the internet, go to your Settings, then scroll to the bottom to About Device. On this screen is a Firmware Update option, this will check for and download the latest. Once it's downloaded you'll be prompted to plug your tablet into the charger and restart it to apply the firmware.
Feb 05, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Archos 101 Internet Tablet Logo
140 people viewed this question
Top Archos Computers & Internet Experts
fordexpert
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
