Question about Kids II Baby Einstein Musical Motion Activity Jumper
Cloth seat is too small
I can't attach the cloth seat all the way to the plastic seat, it's too small for it and the cloth seat is lopsided ..what should I do?
Check to make sure you have it lined up with the plastic portion. The plastic ring rises in the back and dips down in the front, so if the cloth is sideways in the plastic ring it wouldn't fit properly. The warning tag should be in the back where the ring is the largest. Hope this helps.
Posted on Apr 28, 2012
LG Tone HBS-730 won't turn on. I charge it and the red light comes on but when I flip the power switch it doesn't turn on. any help?
First a couple of questions:
  • How old is the unit?...Battery could be spent and can no longer hold a charge.
  • Is the switch working properly? You should feel a discernable "click" when you turn on the unit. If you don\'t, the piece that moves the on off switch within the unit has probably broken.
    • Fix for broken switch:
      • Get some quality small screwdrivers (flat head and Philips), a small, single color, Terry cloth (to catch small screws), a cutting blade (utility knife), small needle/pin, and a well lit work area.
      • Place Terry cloth on to work area
      • Find rubber stopper just above switch and adjacent to speaker wire that covers the Philips screw.
      • Use needle/pin to remove rubber stopper. Chances are it will fly off once freed from unit, so prick it with needle to attain a firm hold.
      • Use small Philips screw driver to remove screw. Terry cloth should catch screw and keep from rolling off into oblivion.
      • Use utility knife to pry open plastic casing at the seam. It may be best to start at top near the screw hole and work your way down. Use small flat head screwdriver to place between opened area to assist in helping your progress downward. Eventually the entire casing will pop off.
      • Examine the on off switch actuator to determine if this is the problem by moving it back and forth. The actuator should move a small black switch on the circuit board. If the actuator is broken, the switch will move back and forth w/o moving the black switch.
      • If it is determined that the actuator is not moving the switch, use small screw driver to move black switch to "on" position and look/listen for activity, to verify that switch is working.
      • To fix broken actuator, remove it from casing and place on Terry cloth. From examination, you will notice that tab(s) at the bottom have bent or broken off. To repair, a simple solution was to flip the actuator and cutout a the middle section of the tab opposite of the broken end using the utility knife. Be careful to cut too much so that it would not be able to move the switch.
      • Replace the actuator back on the sliding mechanism and test to see if the actuator moves the switch properly. If you cut too much, all may be lost! Perhaps some super glue and a tiny spare plastic piece to attach to actuator may work.
      • Replace plastic covering and replace screw and stopper. (Be careful to return speaker wire knot inside unit to its proper place)
      • Again, check switch to verify that it is working properly.
      • In future, take care when turning on and off the unit. Perhaps too much pressure or faulty plastic may have been the cause of it failing.
May 19, 2014 | Radio Communications
  • How old is the unit?...Battery could be spent and can no longer hold a charge. Replace battery.
Back of seat adjustment
at the front of your seat(left side for the driver seat & right side for the passenger seat)rite at the curved corner in front of the seat beside your knees, the cloth seat has a hard plastic corner guard over the top directly in the middle of the corner in the front of the seat, and smack in the center is a up & down switch similar to that of the back seat window switch. it is well hidden & I had to have my head down there to discover it in the year2010, on a 1996 auto. the previous owner of the car did not believe me.
Apr 19, 2013 | 1996 Oldsmobile Cutlass Ciera
I replaced my drivers seat in my '04 Liberty and whether I buckle or not the alarm goes off for the first few minutes of driving. It's incredibly annoying and was hoping I could gets some answ
well I hope the guy that replaced your seat,know that there is 8 different one for your jeep/ there is one with or with air bag and
F=>}}}202}654638" type="radio">(w/o air bag); (bucket), (LHD), cloth, elec, high back, R. (w/OPDS)
EFE}A}}202}654639" type="radio">(w/o air bag); (bucket), (LHD), cloth, elec, low back, L.
EFD}A}}202}654640" type="radio">(w/o air bag); (bucket), (LHD), cloth, elec, low back, R. (w/OPDS)
F==}}}202}654641" type="radio">(w/o air bag); (bucket), (LHD), cloth, man, high back, L.
EFF}}}202}654642" type="radio">(w/o air bag); (bucket), (LHD), cloth, man, high back, R. (w/OPDS)
EFC}}}202}654643" type="radio">(w/o air bag); (bucket), (LHD), cloth, man, low back, L.
EFB}}}202}654644" type="radio">(w/o air bag); (bucket), (LHD), cloth, man, low back, R. (w/OPDS)
EFE}B}}202}654645" type="radio">(w/o air bag); (bucket), (LHD), leather, (elec, low back), L.
DE@}}}202}654646" type="radio">(w/o air bag); (bucket), (LHD), leather, (elec, low back), R. (w/OPDS), heated
EFD}B}}202}654647" type="radio">(w/o air bag); (bucket), (LHD), leather, (elec, low back), R. (w/OPDS), non-heated
Nov 23, 2012 | 2004 Jeep Liberty
How do i take off the armrests from the bucket seats
  • On most vehicles the arm rest are attached the same way, here is something you can try...Put the armrest in the upright position. Look along the bottom and sides of the armrest where it connects to the body of the seat. There should be small circles like tabs if the armrest is made of plastic, and there should be a seam that you can look through if the arms are made of cloth.
  • Pop out the tab or peel back the fabric to reveal the holding mechanism. If the chair is screwed in then you'll need a screwdriver, and if there's a nut or a bolt then you're going to need a socket wrench.
  • Hold the armrest up and make sure it doesn't move. Unscrew or unbolt the arm from the bucket seat. Pull the arm outwards once the hardware is removed.
  • Nov 13, 2012 | 2007 Dodge Grand Caravan SXT Minivan
    I want to washhe padding of my beline ferrari seat and can't get them out,any help??
    if its fabric i found that the powder laundry soap,bucket of water and a microfiber wash cloth ....put 1 scoop in about 3 gal water wet cloth squeeze out most water ..leave damp wash repeat......step back and be amazed!!
    Aug 16, 2012 | Ferrari Beline Toddler Car Seat
    How to take the cloth off the seat to wash it
    Although I must ada that it's very complicated... If you unscrap the cloth from the top bar, and push the fabric back, there is a prong that you must push in to seperate the bar, from there you can take the fabric off (you will need a small screw driver). AS far as the seat, turn the jumper up-side down and ppush the seat out.... It takes less than 5 minutes to take fabric off but almost 45 minutes to replace after washing, (but it's a must to keep germs away)... :)
    Aug 02, 2011 | Kids II Baby Einstein Musical Motion...
    Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
    Instructions
      • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
      • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
      • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
      • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
      • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
      • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
      • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
      • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
      • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
      • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
      • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
    May 10, 2011 | Toys
    The bags keep falling off
    The nozzle pictured upon which the bag holder mechanism broke on my machine. Took it to Oreck dealership twice and he kept replacing the bag holder, but mostly trying to sell me a new vac.
    Problem was, the bag holder mechanism itself was no longer attaching to the exhaust port because a major portion of the attachment device simply went missing. Notice that in the pics I post there is obviously something missing. A product failure. We don't abuse our stuff.
    Solution? I drilled two small holes on either side of the bag holder mechanism and then fed a very small zip tip around the mechanism and around the plastic cloth bag holder support so it can no longer disconnect. Key to this is to feed the zip tie from behind the plastic cloth bag holder support so that the fat part of the zip tie does not interfere with the connection of the bag support to the bag holder.
    Here's a pic of what I did.
    Feb 15, 2010 | Oreck XL Ultra Bagged Upright Vacuum
    How do I attach the fabric seat of my evenflow supersaucer? It was detached for washing and now I cannot figure out how to re-attach it. Fran. email:franblakely@yahoo.ca I have the same problem the...
    The seat back should be screwed securely to the other half of the plastic seat ring. Position cloth seat over seat back, lining up red diamond on cloth seat with inverted 'V' notch on lower edge of the seat back. The plastic tab and elastic straps go around outside of seatback and back through the narrow space between the two parts of the plastic seat. The elastic loop then hooks around the tab on the underside of the plastic seat ring.
    Mar 30, 2009 | Evenflo Exersaucer Triple Fun Active...
    Kids II Baby Einstein Musical Motion Activity Jumper Logo
    148 people viewed this question
    Top Kids II Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Kids II Toy Expert? Answer questions, earn points and help others
