Question about Nokia 5230 Cell Phone
My nokia 5230 keeps on flashing a white screen then goes off, what can i do?
When ever i turn on the phone it justs flashes a white screen and then turns off.
  • Nokia Master
  • 2,148 Answers
Hi.You can solve this problem by yourself so Click here1.to do it by yourself or contact mobile repairing shop.For your file there are 4 types of 5230 model so follow this link Nokia flash file and click BB5 support >>select 5230 and choose the type (RM....)which is written in your phone.Good luck
Posted on Feb 10, 2012
  • 229 Answers
SOURCE: nokia 5230 mobile flashing code
unlock using flash damages the phone,try unlock codes here http://www.unlocking4u.com/nokia-5230-nuron/rs6wp9/
Posted on Nov 23, 2010
  • 32 Answers
SOURCE: constant flashing envelope on front screen
This is common on the Nokia N79. Your Sim card probably has text messages saved on it and the flashing icon is showing your sim sms memory is full. In the inbox go to the setting and view the sms on the sim, delete them and the message icon should stop flashing.
Posted on Apr 19, 2009
SOURCE: Nokia 6500 power up the screen flashes on and off
I had the same problem, remove the SD Card and I betcha it works, mine was the same and I removed the SD card and works fine (SD Card is rooted though)
Posted on Jun 18, 2009
  • 523 Answers
SOURCE: The phone turns on then the screen goes white
Hi Friend,
The problem may be because any software my got hanged or any virus may create this problem so kindly check it out.
Or you may try the below steps,
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card.
Check and revert back
Thanks and revert back
Regards,
Ayyasam
Posted on Jul 31, 2009
AldRezaine
  • 995 Answers
SOURCE: nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Posted on Mar 26, 2010
Testimonial: "yes, it did get corrupted by a software and I had to give it to some workers at nokia to fix it, I lost the info on the phone (except memory card)"
Nokia 6300 Memory Store Not Ready Then White Screen Appears
Bro. . Goto any mobile software shop and flash your mobile. This is software problem
Feb 25, 2012 | Nokia 6300 Cellular Phone
I instal nokia softweare update end mobile not tur on, wat tu du?
Now the only thing you need to do is to contact mobile repairing shop or flash it by yourself using pheonix.So, if you want to do it by yourself Click here1.For you 5230 flash file, due to different types of this particular model I could not give the right file so after you get Nokia flash file...at the left task-bar you'll be noticed BB5 just click it and you will see different kinds of Nokia models select 5230 and choose the right type (Rm.000) to download.Good luck.Thanks for visiting fixya.
Oct 16, 2011 | Nokia 5230 Cell Phone
Nokia x3 is not switching on.When I am trying to turn it on the nokia logo flashes and then white screen keeps on flashing for 4-5 times and the phone turns off.Please help
The only way to get rid from this problem is to flash/update the phone so follow this if you can I've done and solved many times.So try it.Or contact mobile repairing shop
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link X3 file or Nokia flash file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck.If you could not do please contact me.
Jul 25, 2011 | Nokia X3 Cell Phone
Nokia 5230 keeps shutting off and turning on by its self.
Hi, when a phone it is continuously rebooting, it means that memory has been affected by VIRUS.
VIRUS can damage a phone in no time. VIRUS can be caused by downloading applications on your phone through the internet, or might be from data transfer from a phone to another phone.
To remove the VIRUS, you will need to flash the phone memory. Flashing the phone will restore back the phone to it normal state.
You can use this link to see how to flash your phone
Flashing a cell phone will erase carrier data from the memory. Cellular companies can usually do this for a fee. Online buyer sites sell the software kit that will flash a cell phone from home computers.
To flash a phone you will need to rewrite the PRL file by connecting your phone to a computer with the needed equipment. Your best bet is to take your phone to a dealer that flashes phones on a regular basis. For more information
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
May 23, 2011 | Nokia 5230 Cell Phone
My nokia 5230 mobile was suddely switched off. it was charged fully in morning. please help
hi
i have two solutions for you:
1- remove SIM Card and try to turn on your phone.
2- try turn on your phone with another battery.
maybe the lifetime of your battery is ended or it is damaged.
otherwise take your phone to a phone servicing center and then ask for FLASH.
(Flash your phone)
Jan 27, 2011 | Nokia 5230 Cell Phone
My 3110c phone won't turn on anymore. Help!! I just turned it off one time and when I try to turn it back on, It won't turn on completely anymore. It will still show the nokia screen and then a white...
My 3110c phone won't turn on anymore. Help!! I just turned it off one time and when I try to turn it back on, It won't turn on completely anymore. It will still show the nokia screen and then a white screen will flash 3 times and then the phone will turn off. Could anyone help me please?..
Aug 08, 2010 | Nokia 3110 Cellular Phone
Forget my security code of nokia 5230
Bro -Go to some mobile repairing shop and ask him unlock or full flash it , it will delete all the data in it
May 21, 2010 | Nokia 5230 Cell Phone
Phone wont turn on
may be the drink goes into the cpu and flash
in this case anything could happen
pleasae reball the flash ic and the flash it
Jan 28, 2008 | Nokia 7373 Cellular Phone
Nokia 5230 Cell Phone Logo
707 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
