Question about OKI C3400n Laser Printer
Oki c3400 toner sensor error immediately after changing drum. Have tried cleaning the sensor on the toner cart and the wall of the printer. Can I disable this function?
  • gouval Jan 26, 2009
    I have the same problem.
I found the solution here.
A plastic thing was closing the sensor window. Open the window and you will solve the problem.
Posted on Jan 26, 2009
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
I have attempted to install 3 different black toner cartridges in my OKI c3400. I keep getting an error: "Toner cartridge lock lever is improper, drum missing, or toner sensor error. OFFLINE." I first...
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
Mar 16, 2010 | OKI C3400n Laser Printer
I have just put new toner cartridges in my Oki C3400 and I am getting the message of "toner sensor error"
look this solution
here the solution for your problem
i hope that it's helpful .... bye
Mar 05, 2010 | OKI C3400n Laser Printer
I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Feb 11, 2010 | OKI C3400n Laser Printer
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
Toner Error
Check to make sure that the sensors are clean and play around with the lock arms. Reset the machine and also download the utility from the oki service website to get exact error message.
Jan 27, 2009 | OKI C3400n Laser Printer
OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Jan 19, 2009 | OKI C5100n Laser Printer
I have an Oki C3400 that wont print
Could very well be the sensor window. I suggest looking at the side of the drum on the right side and pushing a q tip into the opening. heres an older model thats sort of similar instructions.
Also you can check the exact error code here.
Dec 10, 2008 | OKI C3400n Laser Printer
Oki c3400, Have replaced cyan toner 3 times now but still saying toner empty cyan
Check the window on the side of the drum where the sensor sits. It is on the right side of the drum and can be pushed open with a Q tip it is a small black window.
Nov 20, 2008 | OKI Office Equipment & Supplies
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
OKI C3400n Laser Printer Logo
4,068 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
