Question about LG HT503TH Theater System
Lg ht503th home theatre has a problem after updating. when i turn it on, after 15 seconds it turns off by itself
I started updating. When it stoped i removed the disk and unpluged it. Then when i turned it back on, it wouldn't do anything, and is turning off by it self after about 15 seconds.
  • Allrounder
    Allrounder Jan 04, 2014
    For some reason your update failed, you have to desolder the flash memory (IC 503) from mpeg PCB and write it again using an external programmer.
  • Allrounder
    The flash memory type could be SST25VF016B or Intel 016S33B, 2MByte flash, you have to be sure wich type is. Make sure you erase the memory through its end, that means 2001FF. After that write the BANK30.rom into flash (the file BANK30.rom inside the zip archive provided by LG website, DO NOT RENAME THE ZIP INTO ROM, like LG tells you in those stupid instructions). Probably this is the mistake you did when you burned update CD. When writing memory make sure to select device end to 1FFFFF, otherwise your hometheatre will not start.
SOURCE: Unlock LG home theatre model LH-SW5100
at "no disc", press "pause" and enter "314159". when it shows CODE__, enter "0" for all code, press "pause" and the power button.
Posted on May 19, 2008
gsalmen
  • 77 Answers
SOURCE: lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Posted on Jul 09, 2009
SOURCE: LG Arena won't turn on after firmware update
I downloaded the LG Mobile Support Tool at http://www.51spsoft.com/Download.asp?ID=34522, which easily downloaded and installed the right firmware for me.
Posted on Aug 08, 2009
skyhoneybear
  • 17 Answers
SOURCE: Phone turns on but wont go past the start up rumor by LG screen
You need to take your LG Rumor back to the store were you bought it. If you have insurance they will fix it or give you a new phone.
Posted on Aug 16, 2009
  • 8457 Answers
SOURCE: lg 50 in clicks but won't stay on.
Ur power board need it replaced,LED indicator light not sustaning power.
Posted on Jan 05, 2010
My LG HT503 is locked in Bypass, I can not choose other setups as I could before. Can someone give me an advice?
When the theatre is in the standby mode press and hold STOP button on the panel (not the remote) for some time - it should UNlock
Dec 31, 2012 | LG HT503TH Theater System
I have a LG Record reciever home theatre model is LH-RH9691 and im having a problem with the volume only when the radio is working. It can only turned up slightly when set to max volume. But when...
in lg home theater system in video mode the complwte speaker will work and in mp3 only two will word .the radio get only a min volume in lg due to the range of antina
Apr 25, 2011 | LG Audio Players & Recorders
I have a lg dvd receiver 503th and when i try to play any dvd the image of the movie leave turning the tv into a black screem and after 3-6 seconds the image comes back. this happens along all the movie...
Try configure the color system that apply to your country or clean the lens gently by using soft cloth and a little amount of isopropyl alcohol. Apply a little amount of alcohol unto cloth and gently wipe the lens and try play your dvd
Jan 12, 2011 | LG HT503TH Theater System
Purchased LG's LHB335 home theatre 5 days ago to enhance my LG 42LBX TV. Problem with home theatre sound as the audio cuts out for a couple of minutes every 15-20 minute intervals. Problem is intermittant...
i bought mine in january 2011 and just started having the same problem. i have to turn the head unit off and back on again to get sound back. any fixes for this yet?
Dec 06, 2010 | LG LHB335 Theater System
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
Sound to mute
i would suggest turning off the system, disconneting it from the outlet and plugging it back in, the should reset the settings, please post with what you try to do.
Thanks and i look forward to your post.
Nov 13, 2008 | Audio Players & Recorders
MY HOME THEATRE AMP. SHUTS OFF ITSELF, AND SOMETIMES SCREAMS W/ N
First suggestion is to recheck all the connections
Rifaa
Nov 12, 2008 | GE GTD120 System
LG HT503TH Theater System Logo
114 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
