Question about Lexmark T644 Laser Printer
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
We have 3 trays. Tray1 & 3 are 500 sheet drawers. Tray 2 is 250 sheet drawer. Previous problems with 2 chq forms being pulled from tray 2 when printing and jam occurs. Trays 1 & 3 never have problems. Today we had tray 2 jam - starts printing on one chq form but for some reason a second form gets pulled thru behind and jam occurs. Now there is an error message that 'Tray 2 Missing' but it is in place and the guides are properly in place. thank you. Fran
    Genius:
  • 1,087 Answers
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Posted on Feb 21, 2012
SOURCE: Cannot change paper size in drawers
Few things check, first if the paper trays have manual adjustable levers that tell the printer what type of paper is in the tray. The other option is to go to your printer menu from your operating system and check paper assginment on settings.
Posted on May 19, 2009
don_farr
  • 1018 Answers
SOURCE: can't print from bottom drawer, will only print from tray,
There are at least three possible solutions. The first two are simple the third is fairly complicated unlr=ess you can read a hex dump of a print file. 1) Use the front panel "Paper Menu" to select the tray. 2) Check the driver settings to make sure the driver is set to "Auto" or the correct tray. 3) Set the driver to "Print to File". When prompted to name the print file, name it "tray_fail". If you do not know how to read this file, send it to me at janddgasrepair@verison.net and I'll be happy to take a look at it and see I I can correct the problem. Don
Posted on Jun 03, 2009
yammy_alf
  • 666 Answers
SOURCE: My Lexmark E450dn will pull 3 sheets through, even
Try to check feed roller page break pad must be in good shape, if not it pick multiple pages to print and that can occurred jam.
Posted on Mar 24, 2010
tbreeze47
  • 3083 Answers
SOURCE: I have a Lexmark T632
Hi Sandra,
There are two drawer file cabinets that you can get at Walmart, Office Depot, or Staples. If they're not wide enough, you can get a piece of formica or plywood to extend the top surface area. If you get lucky, you might find a file that will be wide enough. I use a file cabinet for mine, and it's really handy.
Good luck, thanks for using FixYa, and hope this helps make your boss happy!
Posted on Aug 27, 2010
Corysf62
  • 188 Answers
SOURCE: Lexmark T632 has 2 (ea) 500 sheet drawers, but
go to Menu, reports, and print out the top report.
This will show you what the printer sees as the default tray, and what paper size and type are set for each tray.
If you have plain paper in each tray, make sure that the setting page also shows that each tray is set to letter, plain.
This printer sets the tray type automatically, based on the way the tray is set. There are little tabs on the side of the tray that change as you change the size of the paper with the paper guides.
If the paper guide is set even one click off, this can cause the printer to read the paper size incorrectly, and thus will not change to the next tray. ( if it thinks that tray 2 is A4 paper, but you are printing letter, it will not change to tray 2).
if the trays ARE set correctly, but the printer is still reading it wrong, then there could be something wrong with the sensor ( metal fingers and switch ) inside the printer.
Posted on Mar 02, 2011
Error Code E07
  • Open the drawer the printer is currently pulling from when the error message "E07" appears on the display. Verify that the paper in the drawer is the correct size and close the drawer firmly!
  • Oct 23, 2014 | Copystar CS-1500 Copier
    10.1002 supply error
    This error indicate the affected cartridge...
    10.1002 = Magenta e-label is missing..
    you need to reinstall the printer..
    Are you sure that the print cartridges are genuine!!
    ->Open the front access door completely.
    ->Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
    ->Grasp the center of one of the print cartridges, and then pull it straight up to remove it.
    ->Hold the print cartridge so that the imaging drum faces the bottom of the print cartridge drawer, and then insert the print cartridge into the correct slot.
    ->When you are sure that you have genuine print cartridges installed, close the print cartridge drawer completely.
    ->Close the front access door completely.
    If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
    Dec 26, 2012 | Office Equipment & Supplies
    10.1000 supply memory error
    hi,
    10.00X is the error code displayed when
    • Cartridge is not installed correctly
    • Use of refilled cartridges
    in your case x is 0 which means that black color cartridge had a problem
    problem may persist in slot holding black cartridge and /or in the cartridge
    just do steps below
    solution 1: check all cartridges are in right slot it is better to remove and fix it again
    solution 2:
    clean the surface of metal contacts with lint-free cloth
    the image below will show metal contacts
    solution 3: Insert the problem print cartridge into a different slot
    Follow these steps to determine if the print cartridge or the slot it sits in is causing the error.
    1. Open the print cartridge door completely.
    2. Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
    3. Remove one of the non problem print cartridges from its slot.
    4. Install the problem print cartridge into the empty slot.
    5. Install the other print cartridge into the slot of the problem print cartridge.
    6. Close the print cartridge drawer completely.
    7. Close the front access door completely.
    • If the error message persists , replace the problem cartridge with new one(problem is in cartridge)
    • If the error message is gone , contact HP to troubleshoot a faulty slot.
    regards,
    cseian
    Dec 16, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
    Paper not pulling from tray 2 when tray 1 empties - Lexmark T654
    For the majority of the Lexmark printers, all that needs to be done is to set the paper size and type the same for each drawer. Example - drawer 1 & 2 sizes are set to letter, drawer 1 & 2 paper types are set to plain. Set up this way, when drawer 1 empties, the printer will automatically switch to drawer 2 to supply the paper.
    May 20, 2010 | Lexmark Office Equipment & Supplies
    My printer keeps jamming going threw the fuser what do you recomend I replace thanks
    pull the drawer out and check to see how many fingers are sticking out of the paper size snap in plate on the side of the drawer. letter size is the 2 bottom fingers if there are more or different fingers check to see where the paper slide inside the drawer is set if its not perfectly centered in the whole for that size paper the wrong fiingers will cause a timming issue. if these are right
    print the network page and see if it prints smaller than the full page or if its missing the solid line that forms the box around the outside of the network settings at the bottom of the page. if either of these is true then replace the paper size board located behind the logic board.
    if all of these are right either the narrow media or the exit sensor on the fuser itself will be the cause
    Nov 02, 2009 | Lexmark T630 Laser Printer
    Copystar 5035 - drawer 2 - we had not been using drawer 2; tried to load it with 8.5x14 paper, however, now that we are trying to use the drawer, we are getting an error message "paper drawer is out of...
    You have to reset the drawer by; 10871087 and run SIM 906
    You should be able to just key in the Code you wish, then hit the print key to activate.
    Then use the touch screen to reset then print key again.
    Jan 26, 2009 | Kyocera Copystar CS-5035 Copier
    DregDrawer full message won't clear
    When you need to empty the grounds draw remove the drip tray and pull out the dregs draw - don't open the side panel or turn off the machine, - It works for me!!
    Feb 20, 2008 | Saeco Royal Professional Espresso Machine
    Doc 12 Error Code
    You Have to Clean a litle square reflexive patch that is located on the IBT Belt.
    Just remove the waste developer botle, turn the orange handle CCW, remove the 2 external screws of the IBT Assy and pull out the Transport drawer and IBT drawer. clean the patch reinstall and thats it.
    Feb 14, 2008 | Xerox DocuColor 12 Color Copier
    Error Msg: Maintenance drawer A is missing - Phaser 8200
    There is supposed to be an orange chip on the back of that tray.
    If that is not present or seating properly that will cause that problem.
    Pull out the green tray and see if the chip is snapped on the back ot the maintenance tray.
    Oct 17, 2007 | Xerox Phaser 8200 Laser Printer
    Lexmark T644 Laser Printer Logo
    593 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
