Question about Zonet ZNS8030 USB Lan Disk module (turns USB HD into NAS network drive)
Zonet ZNS8030 refuse connect from MAC
The drive gives authentication error when trying to connect to the smb share from macbook
SMB
check if there's an error code in the completed queue.
Also it would be helpful to know what kind of operating system is on your computer since MAC and Windows 8 are not that easy through SMB.
Check if you shared the file on your computer to full acces rights
May 28, 2013 | Konica Minolta Bizhub C454 Color Copier
How to sync verizons LG 840 with a mac computer to sync music photos etc.
For a MAC, I believe you need an SMB application. This is not free for mobiles, but I'm not sure on the MAC. SMB is a file sharing protocol that is standard for Windows file share and transfer. Apple has their own protocol that is exclusive Apple. The SMB interface app allows you to share files with a Win computer via local LAN. I do this with WiFi on my Android - PC. Really nice for quickly posting pics to net drive when you get home from outing. The Android mobile app on my LG Lucid that I use is Ghost Commander. It's a bit clunky, but once it's set up it's great for getting files from PC or posting pics-vids etc from smart phone. There are Apple SMB apps for iPhone, to do this, but the Android was free.so my LG won this personal use setup.
Dec 31, 2012 | LG Lucid VS840 4G Verizon
Hi Am having kyocera 4050 b&w Copier i have problem with my scan its showing the error code is 1102 can u help me
Here is what an 1102 error is and what some of the things to look for are.. hope it helps..
1102 SMB(SMB)
Error: User/Password or SharedName/FolderNameDomain name not entered as Domain UserInput
User Name with one of the form "Domain\User", "Domain/User", "User@Domain"SMB)
User Name/Password or Shared Name/Folder Name ErrorSpecify invalid User/Password (includes unspecified)Input correct User Name/PasswordSpecify the User who is not permitted for accessing to the folderInput correct User and Password
Check access limit for send destination folderSpecify invalid Shared NameInput correct Shared Name
(See the reference for the symbol which is possible to use for Shared Name)Host Name ErrorCheck if any prohibited letter (see the reference) for Host Name is included or notSCAN TO EMAIL(SCAN TO EMAIL)
User Name/Password ErrorUser ID for Authentication is not entered/entered wrong User ID
Wrong Password for Authentication is enteredInput User ID/Password which is used for Authentication from [Advanced] on Command Center correctly
([Login User Name] on [POP3] page or [SMTP] page)
It's actually related with SMB.
The shared folder on the server may be blocked by an open ghost connection.
A restart of the samba service may repair
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Office Equipment & Supplies
Will not connect to mac from dell pc?
Is your firewall turned on your dell PC?
did you setup your mac for sharing with smb?
you can turn smb on by going to apple>system pref>sharing>file sharing> options and click the check box for share files and folders using SMB( windows)
Feb 26, 2011 | NetGear WNR2000 Wireless Router
How do i connect my Dell 1800MP to a Mac laptop?
You will have to connect them to the same network.
You also have to enable file sharing in system preferences on your mac. When enabling file sharing enable SMB sharing. You can choose there the folders to be shared.
Feb 26, 2011 | Apple Computers & Internet
I use on my PC (Acer/Compac) My Pictures/Adobe Photoshop for the pictures I have. I have gone into the Properties section to add more information on each individual pictures. I than burned the photos...
  • When you go to the Connect to Server dialog, you may browse the names of computers that are on your local subnet.
  • You can connect to a server via its IP address or DNS name. If it is required or more convenient in your environment, you may also use other valid URL formats, such as:
    smb://ServerName/ShareName smb://DOMAIN;User@ServerName/ShareName
  • The name of the "share" (the shared disk, volume, or directory) must be specified. You will not be prompted for it.
  • You cannot type spaces as part of the share name when connecting. In place of any space in the share name, type: %20 .
  • When troubleshooting a connection issue, you can ping the IP address of the Windows PC using the Mac OS X Network Utility application (in the Utilities folder). A successful ping verifies a TCP/IP connection between the two computers. This is an important first troubleshooting step when there's no response or a timeout for a connection attempt, since SMB connections involving a Mac require TCP/IP. However, a successful ping does not mean the SMB service is also working or available.
  • Check Microsoft support resources for information about setting up file sharing on your Microsoft Windows-based computer. These may include Help files installed on your PC or the Microsoft online Knowledge Base. For example, see this article for Windows XP information: How to use the Simple File Sharing feature to share files in Windows XP.
  • When troubleshooting an SMB connection issue, use Console, which is located in the Utilities folder. These Console logs may help advanced users identify an issue: private/var/log/samba, private/var/log/kernel.log, system.log . Note that some log files only appear when logged into Mac OS X with an administrator acccount.
  • If you are connecting to Windows XP, make sure that the Internet Connection Firewall settings are not interfering with your connection. SMB uses ports 137, 138, 139, and 445. These ports should be open on the Windows XP computer. This may require "Advanced" configuration of the XP firewall.
  • If you are connecting to a Windows SMB resource, check to see if the firewall is blocking TCP ports 137, 138, 139 and 445. After trying the above steps, you may perform advanced troubleshooting by inspecting log entries in the Event Log of the Windows SMB resource (if you have access to it), and/or the Mac OS X computer's relevant logs in the Console application. If those steps do not help identify the issue, or you do not want to perform advanced troubleshooting, than you should contact your network administrator. It may be necessary to contact your network administrator in some situations in order to grant access to your Mac from the SMB resource, or its host network configuration.
  • Mac OS X uses SMB only over the TCP/IP protocol, not the NetBEUI protocol.
Dec 29, 2010 | Compaq Computers & Internet
My MacPro will not connect to the Dell 2400mp; no signal or recognition; what do I need to do?
No signal? Do you mean it will not connect to your wireless?
If you mean you are trying to connect to a Windows XP PC then you need to connect to the computer and mount the share.
Go to top of screen there will be a drop down that says go, connect to server. If the computer is in the list connect to it if not then you have to type the address of the pc, eg. smb://computernamehere or you can use the ip then hit connect. You will need to input the name of the workgroup and the user name and password of that machine you are joining. Select the share name and hit okay, you should see the shortcut on your desktop.
Oct 13, 2009 | Apple MacBook Pro Notebook
Cant Share Printer on MAC
What have you tried? Can the Mac see the printer at all? Is the Share Storage attached to the Mac or the Windows machine?
Aug 02, 2007 | Maxtor Shared Storage II (S01R320) Hard...
Zonet ZNS8030 USB Lan Disk module (turns USB HD into NAS network drive) Logo
81 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
