No beep, no bios, no signal to my monitor but only the fans moving on an asrock mother board. What could be the problem, solution?
    Problem Solver:
  • 11 Answers
From the brief description that you have given. it seems that your computer is set on the ....dos.. setting. most people forget that all(I.B.M.) computers still use dos. the windows programs is actully a ZEROX. program. of course with some mods.it translates the dos into icons that you may use the point and click method.
Posted on Feb 09, 2012
My computer works normaly with an single core athlon 3200+ but when I use an Athlon 4400+ or 4000+ dual core, it just wont boot. The fans are running and lights are on but there is no signal on the monitor...
take a look at the motherboard manufacturers website and see if your motherboard will accept a 4400. You may need to update the bios on your board to accept the faster processor. You need to be careful if you flash the bios. do it wrong and you can write the board off.
Good luck
Aug 11, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
What does a AMI bios beep code of one long and 9 short
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code
Descriptions
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Jun 01, 2010 | Asrock 939SLI32-eSATA2 (939SLIESATA2)...
My pc monitor is blackout and no beeps whaen i start up even my hdd is not spinningmy cpu fan is working what is the problem tell me what can i do pls , As done by me----- 1. Clean the RAM memory and try...
If do not hear any beep then it means that the mother board is dead you can try clear the BIOS by removing the battery of the mother board for 5 mins or by shorting the jumper for clearing the BIOS if that didn't help then you have to repair the board or replace it.
Feb 09, 2010 | Asrock P4I45GV R5 Motherboard
No Beep sound during startup. Motherboard or Processor ?
ok
pull cmos cell for 15 minute then check so all settings of bios are reset.
Also Refix RAM memory reattach all connection to motherbord.
Jul 16, 2009 | Asrock P4I45GV R5 Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
Pc does not boot
my pc is asrock m266a board intel pentium 4. it does not boot nor reach to bios startup nothing shows on the monitor ketbord and mouse are off only the fan runs i tried to take everythin out and assemble it again no results found pliz help . moses
May 07, 2008 | Asrock M266A Motherboard
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
