Televison & Video Logo
Posted on Feb 09, 2012
How to disable distance alert cannot find an off in i manuel
How can I use my B&O phones as intercom only? I have done this successfully, but I have a constant alert: no dial tone on both phones. Can I remove this alert?
If you want to use your Bang & Olufsen (B&O) headphones as an intercom only, without any phone-related functionality, you can try the following steps to remove the "no dial tone" alert:
  1. Disable the Bluetooth and/or cellular data connections on your B&O headphones and/or mobile device, if applicable.
  2. Check the user manual or settings menu of your B&O headphones to see if there is an option to disable or customize alerts or notifications. If so, try to find and disable the "no dial tone" alert or any other phone-related alerts.
  3. If you cannot find an option to disable or customize the alert on your B&O headphones, you may need to use a third-party app or tool to block or filter the alert. For example, you could try using a call blocker app that can silence or redirect calls and notifications.
  4. Alternatively, you could try to physically disconnect or remove any phone-related components or cables from your B&O headphones, such as the microphone, speaker, or charging cable, if possible. However, this may affect the functionality or quality of your headphones as an intercom.
Keep in mind that removing the "no dial tone" alert or disabling phone-related functionality on your B&O headphones may affect their warranty, compatibility, or safety. Therefore, it is recommended to consult the manufacturer or a qualified technician before making any modifications or repairs to your headphones.
Hi. It is supposed to be a wake up alarm function in my Forerunner 305, but I can't find it (I really used that function in my old Polar). Where can I find the settings? Best /Fredrik
The only alert that comes close to being a wake up alarm is the Time alert function. Press Mode and then select Training. Select Training Options > Alerts > Time/Dist Alerts. In the Time Alert field, set the alert to Repeat (instead of Once or Off). Enter the time that you want the alert to sound in the Alert At field. Then press Mode repeatedly to exit the menu.
The manual for the 305 is available here http://static.garmincdn.com/pumac/984_OwnersManual.pdf . The time/distance alert picture is given on page 9. Links to additional documentation are available here https://buy.garmin.com/shop/shop.do?pID=349&ra=true .
I hope this helps.
How to remove the email alert from the screen
It depends on which mail program you are using. You should be able to disable the alert right in the panel of management of that mail program. Usually you might see a small icon in the system tray which is the bar at the bottom right corner of the screen for that mail program and you can right click on that and choose options or something and disable the alert. Give me more details and I will let you know the steps.
Have Talkabout 250 and want to turn off the beeping. any ideas
The following instructions are for the T289, which is very similar to the T250. It is possible they will work to turn off your beeps.
Alert Tones
The Alert Tones (beeps) on the Talkabout radios are set at a fixed volume
level and cannot be lowered. However, Alert Tones can be disabled. When
Alert Tones are disabled, the radio will receive messages at the volume
setting you've selected, but you will not hear beeps when you press control
buttons.
Disabling Alert Tones:
1. Hold down the Monitor button while you turn radio on.
2. To re-activate Alert Tones, turn the radio off, then on again while holding
the Monitor button down.
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
3helpful
Unexpected end tag: expected b actual font. What's this please?
Tools > Options > Notification Settings > alerts and Messages > Untick everthing under "Show messages about" and "show alerts from" Tools > Options > Advanced disable "Automatically disable Extras"
How to disable the email alert
Go to tools menu>Audio & ring tones>Alert type>Message alert tones. Choose silent and click set. This will disable all email and voicemail alert tones.
Manuel for midland wr-100 weather radio
http://www.midlandradio.com/comersus/store/catalog/WR100.pdf
1helpful
How do you disable the email alert on a Samsung SGH-A707 phone?
When you are in Mobile Email and logged into your mail service, under OPTIONS there is an option to change EMAIL ALERTS. At least it is for Yahoo. I am assuming it would be the same or similar for other email services.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
