Question about Akai LPK25 Laptop Keyboard Controller ( 2009 ) USB Controller
The mini end of the usb power cable for my akai lpk25 has bent will any usb to mini usb cable work as a replacement lead ?
3 Suggested Answers
SOURCE: AKAI LPK25 WONT WORK ON
Maybe, It doesn't work because the driver you installed. It is for other versions of operating system. I am also using windows 7 like you.Dont worry, You can still use your installer/driver from other versions of operating systems. Before you installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatiblity". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D
Posted on Dec 04, 2010
robertmail
hi,
every drive rrelated problem can be easily solved here on this page: Driver Update Software. I hope this helped.
Robert
Posted on Jan 05, 2015
Diagram akai
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 01, 2014 | Akai APC20 Compact Ableton Performance USB...
Usb port's pins are bent
Hi
usb sockets are normally pretty standard but without the make and model I could not be 100% certain.
https://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=18957
regards
Jul 29, 2017 | Akai Professional Akai LPK25 Laptop...
My usb jack fell out of my LPK25. Is there a away to get it fixed?
You would need to take it to a electronics repair shop and get the usb port re-soldered in there.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 04, 2011 | Akai LPK25 Laptop Keyboard Controller (...
Wat driver do i need for the lpk25 to talk to windows 7 64 bit?
Feb 18, 2011 | Akai LPK25 Laptop Keyboard Controller (...
AKAI LPK25 WONT WORK ON WINDOWS 7 (cant find the right driver)
hi,
Robert
Dec 04, 2010 | Akai LPK25 Laptop Keyboard Controller (...
Panderson11463@gmail.comthe usb connector inside my lpk25 brole off the circuit board inside the unit. can it be repaired?
Hi did you solve this? I had exactly the same problem .. i had to buy a new one and now the little pins have bent inside the plug on that one!!? What is akai doing ? such a nice idea but REALLY **** parts for such a crucial bit?!!
Sep 18, 2010 | Akai LPK25 Laptop Keyboard Controller (...
Akai LPK 25 Midi keyboard won't play
I had the same problem on Windows 7. Received drivers from Akaipro.com support and installed them. No success. When I plugged the little plug into the LPK25 the light of the sustain key blinked. Using a magnifying glass I discovered the 5 pins where you stick the plug in to, were bent upwards a little and not in line. Using a small screwdriver I bent them down and in line with eachother. Plugged in again, and yes, it worked!
Dec 26, 2009 | Televison & Video
I need a camera cable (USB) for my casio EX-Z9 exilim. How can I find the right one?
You can get the correct lead from almost any large computer or photographic store, it does not have to be the official Casio item.
The lead needs to be a standard USB socket at one end (USB type A) and the other end is a micro USB (micro USB type B). This is by far the most common type for many cameras and phones now so shouldn't be expensive or difficult to find.
Alternatively, ditch the cable altogether and use an external card reader. Removing your memory card and putting it into an external reader to transfer images is usually much faster, especially if you also avoid using the clunky and non-essential software which most cameras are supplied with.
I hope that you've found my reply to be of use and ask in return only that you rate my answer.
Nov 05, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
Akai LPK25 Laptop Keyboard Controller ( 2009 ) USB Controller Logo
290 people viewed this question
Top Akai Computers & Internet Experts
Alun Cox
Michael Vincent Cruz
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
