Question about HP Compaq Evo Notebook N800v (470036-855)
Display can not be fixed
The display of my laptop con no´t be fixed in any position. The hinges don`t keep it in position
Broken hinge on my dv4-2165dx
These WEB sites will show you how to fix the hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Dec 01, 2012 | Computers & Internet
My computer screen won't stay in place
Laptop hinges cannot be tighten. To fix your display hinges, they need to be replaced.
Check out these WEB sites for details on how to replace the hinges.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
Jul 22, 2012 | Computers & Internet
Laptop cover / display hinges locked in full open position
Glad you found the solution because I had never heard of the lcd locking.
Apr 02, 2012 | Dell Vostro 1000 Laptop Computer (AMD...
When turned on it has no picture but sound works
hello!
if your TV stays on, display glows, but there is no picture, most likely you have faulty t-con board and/or display itself. I've encountered the problem with both lately. I'd start with t-con(display adapter) board. it's not hard to replace and cost around $100 top. If that won't solve the problem, then it's a display panel itself. not an inverter, which is the part of power supply, but panel itself. Before replacing t-con, try to reach display's ribbon cable connectors, plugged into t-con board. disconnect first one and turn set on. If you see half of the picture, the display is bad.
If nothing changes, reconnect that cable and disconnect another one. If you see half of the picture, display is bad. If, still you don't get any picture, that's your lucky day! Display is good, t-con is bad. Replacing the display panel will void any reasonable repair option. Those crooks at "parts distribution' selling displays at the price of your TV, when you bought it: $1,500-2,000+. i don't understand why do they practice rip off. most likely to encourage customers to buy new junk and receive hefty bribes from "peoples republics" to stay in business. Anyway, it's a crazy globalism. that's why our country in default.
good luck with your project,
thanks,
Alex.
Jan 30, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How to replace lcd bracket on asus m51sn
Check out these WEB sites for fixing display hinges.Replacing a hinge, or both of them, isn't very tough.
Dec 27, 2011 | ASUS M51SN-A1 LAPTOP LCD SCREEN 15.4" WXGA...
How to fix broken hinges
The hinges needs to be replaced. These WEB sites provide parts and instructions to assist you.
Replacing Display hinges http://www.laptopparts101.com/display-screen-hinges/
Apr 01, 2010 | HP Pavilion dv4000 Notebook
My Y510 hinges seems broken..how do i get fix...i had it just over a yr
If you are considering fixing it yourself, then check out this WEB site on
Oct 18, 2009 | Lenovo IdeaPad Y510 Notebook
Can i fix my broken laptop.
Well, if the display comes on at all, then it must be a loose connection in the wiring. Sometimes this is a simple reseating of the main cable to the mother board which comes down from the display near or around one of the hinges (in most cases). I would suggest, purchasing a cheap external monitor, and plugging it into the rear or video out port if you have one, and switching your display to go to the external monitor, this will work good as a desktop scenario. Otherwise, you need to take it all apart and see if you can find out where the loose connection is, this is no easy task, and should be done by a qualified laptop repair person who has experience.
Mar 22, 2009 | ASUS F3Jp Notebook
Display hinges
This website have many manuals for replacing LCD hinge.
Just search on this website, maybe you will find a manual fit to your laptop.
Mar 20, 2008 | Toshiba Satellite 5105-S501 Notebook
HP Compaq Evo Notebook N800v (470036-855) Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
