Question about Hotpoint First Edition FEW12 Front Load Washer
Machine does not spin ath the normal speed
When machine attempts the spin cycle, it does not spin at the normal speed but moves slowly. Any ideas?
    New Friend:
  • 163 Answers
You got a loose belt or a brake pad stuked, any way gonna need a tech, in this model is a easy job for a tech, but a dificult one for a regular peole...good luck
Posted on Aug 07, 2006
Doesn't spin
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 29, 2012 | Kenmore Washing Machines
Washer does not spin out the clothes very dry, and wilkl pause for over 20mins, i have to move to spin rince and spin out cycle, I got this machine new last week, thanks Diane
Quick silly question(s) ;-0)
Are you selecting the right program? Wool is spun fairly slowly and the speed would not be fast enough for normal garments. If you have selected the right program(s) for the particular garments, I would immediately contact the vendor/supplier as the machine is under guarantee, I presume.
Did they install and test it?
Good luck,
John C
Mar 17, 2011 | GE Energy Star WCVH6260F Front Load Washer
I have a new machine beko wm 5120 W and tried to re-spin some items after they had been through a wash cycle...i turned the dial to spin, chose my spin speed and pressed start...the machine went through a...
No idea why but it happens to us to. You need to cancel the wash, switch off and leave a few mins then retry, not that it may work.
Now the spin cycle has stopped on ours too plus the spin is not actually working, drum is just going round and round slowly! We've had it just over a year so the guarantee has finished too :-(
Oct 31, 2010 | Washing Machines
The machine runs but won't spin.
Does water remain in the machine at the end of the wash cycle? Does the water pump run when it is supposed to? If not, the pump may be jammed with debris or the motor is defective. Can you drain the water by lowering the drain hose to floor level and into a bucket or pan? Does this allow the spin cycle to proceed? It is normal for the machine to test for spin balance (it will agitate further if it is not balanced). Hope some of this helps!
Apr 09, 2010 | Hotpoint WMA32 Front Load Washer
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
My Haier waching machine has a slow spin cycle
I have the same problem with the same washer
Jan 26, 2010 | Haier Washing Machines
Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
May 20, 2008 | Kenmore 24032\24036 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Whirpool Ultimate care II
your lid switch is broken you need to replace it look on the lid of the unit you will see a plastic pin that pushes down on thwe switch when it closes there are 2 screws holding the switch in place but you will have to remove the cabniet to change the switch
Jan 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint First Edition FEW12 Front Load Washer Logo
127 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
