Question about SanDisk Sansa Clip MP3 Player
FM tuner has no audio. the songs do have audio. What happened??
What could have happened ? It was fine and it just quit. I have tried another set of ear pieces.
  • chessforme23 Oct 25, 2008
    fm tuner just quit working on two sansa clip players recorded songs work fine
  • 8,596 Answers
Probably faulty headphone jacks/controller, but reset all the defaults in the menu to be sure. Additionally you can try these soft fixes, but they probably don't apply to your situation:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Why no more sound in left side? the right side is fine. i moved the left side like a seesaw, then i found where the sound occur. is it the wire connection problem inside the left side? what to do?
Opened up one of the earcups and dont ask me how it was just by force. The cable that connects the 2.5 to the speaker is frail and there is quite a bit of shielded cable that can rub against each other over time. I fixed it by removing the cable and soldering in two separate cables of similar size.
Apr 21, 2016 | SOL Republic Master Tracks MFI...
How do I fix the FM tuner to pick up FM signals?
I think you might have fault in the FM tuner section. Most of these are done by a single IC, replacing that will cure the fault I suspect.
Jun 10, 2017 | Audio Players & Recorders
I can't get my tuner to work, but everything else works fine. All I get is static went I turn to the radio stations on both FM/AM
If you are in a fringe area you might need an external antenna to work with your tuner. Happens.
Oct 15, 2015 | Pioneer VSX-D704S Receiver
My rca mp3player m6204-b says music is empty
Having the same problem, I don't understand what's wrong with it
Nov 26, 2012 | Audiovox RCA M6204 4 GB Black Flash...
FM Tuner not receiving - Yamaha R7 receiver
Take the cover off and look at the cable that connects the tuner to the main board. Make sure it is connected straight and tight. Make sure all screws in the back are tight, just in case it is a grounding issue. Iff all checks out and you still have issues, replace your tuner.
Apr 30, 2012 | Yamaha Audio Players & Recorders
TEAC AG-V3050 FM reception was fine and then quit. Checked antena with no results. Internal component? Fuse?
If a unit turns on it isn't a blown fuse. Does the tuner give you indications that it is or is not tuning a station? Change the FM Mode to Mono. You should at least be able to hear FM hiss if the tuner is alive.
Jan 20, 2011 | Teac AG-V3050 Receiver
What is the video format of the player?how many songs can i store in it?
Slim and stylish, the NWZ-S616F Walkman Video MP3 player combines a powerful digital music player with a 1.8" QVGA LCD screen for hours of multimedia entertainment. Listen to your favorite songs, view videos and photographs or listen to your favorite radio stations with the built-in FM tuner. It supports playback of MP3 and WMA DRM and non-DRM audio files downloaded from multiple sources, as well as AAC non-DRM content, so that you can enjoy your music no matter the format or download source. Weighing less than 2 ounces but with the capacity to store up to 2,300 songs, 15 hours of video or hundreds of photographs, the 4GB NWZ-S616FRED Walkman Video MP3 player delivers everything you need to take your favorite entertainment with you. Compatible with Secure Windows Media Audio MP3/WMA/AAC Audio Codec Support Utilizes 3 Clear Audio technologies to reproduce crystal clear, CD-quality audio. FM Tuner with 30 Station Presets Shuffle play among songs from a randomly selected year. Bi-directional screen display
Nov 28, 2009 | Sony Walkman NWZ-S616F MP3 Player
My ear piece will not work?? did but won't now. all volume are up and the speaker works fine, but the ear piece won't
There are two things involved, Its either the earpiece is bad or the problem is from the phone board. I have seen cases like this.
Maybe you should try changing the earpiece first and let's see what happens.
You might just get use earphone to save you the stress for the main time
take care
Nov 19, 2009 | Motorola Mobility i580 Cellular Phone
Lg vu sound quit working
the file could have a virus, for that update your anti-virus or install one. or your ear piece in the phone is bad
Oct 01, 2009 | LG Vu CU920 Cellular Phone
SanDisk Sansa Clip MP3 Player Logo
51 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
