Question about Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs
MV450 SCOTTSMAN ICE MACHINE
HI MATE, LAST TIME I SPOKE TO YOU, RE PROBLEM WITH MY SCOTTSMAN MACHINE, I HAVE A QUICK QUESTION, I CHANGE THE EXPANSION VALVE CAUSE ITS BLOCKING , NOW 4 MONTHS LATER IT HAS THE SAME PROBLEM, NOW IM CHANGING THE VALVE AGAIN. THE PROBLEM IS THE WATER DROP AND WHEN MACHINE READY TO HARVEST ,ICE NOT DROP AND RED LIGHT COMES ON STEADY , IS ANY REASON WHY THE VALVE FAIL QUICKLY.
Many thanks
henry
  • 1 more comment
  • Tiatala Oct 24, 2008
    Hi Mate,
    When theTech change the Expanson Valve last time , he didn't change the filter dryer he only change the TXV , now he is changing both now. I hope there no more to be fixed, its very expensive exercise, the new valve TX is $790.00 and the filter is $150.00 but i have no choice.
    2.
    Do you know where i can get a expanson valve for one of my other machine, I have a manitowoc model DG12020 has two evaporator, one of the expansion valve is leaking, which cause the one evaporator with no ice and the other with ice up to the ice probe. When i check the expansion valve one has ice and the other valve no ice on it.I would much appreacted if you know where i can get those expansion valve. im happy to buy two but i don't know where to look for .
    Many Thanks
  • Anonymous Jan 08, 2009
    ice cantinew make but not remov
  • James Helmer
    James Helmer May 11, 2010
    Was the system filter dryer on the refrigerant side changed at the same time as the TXV was changed. Moisture in a system will freeze in the expansion valve stopping circulation of refrigerant. Under normal conditions expansion valves do not fail in 4 months.
    When installing a new Expansion valve it is necessary to protect the valve body from excess heat by wrapping the body with a wet cloth during the soldering process. Proper instructions are included with each valve when shipped.
  • 828 Answers
Personally I think the prices that you paid for the new TXV and dryer are VERY far out of line.Get what information you can off of the TXV power assembly and valve body along with the manufacturer of the valve and I will see what I can find out for you. If it is the power assembly that is rusted out and leaking there are kits for replacement parts on most valves.
Posted on Oct 24, 2008
Scottsman SCE170A-1B how can i have to make ice faster
The only way to make ice faster for this machine is done with cooler ambient room temperature and colder water temperature from supply water before it reaches water sump tray.
Jun 06, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scottsman cu2026
does the water overflow?,, if its not pumping, its not being told to pump by level indicator or the pump is bad(common issue)
Apr 07, 2014 | Scotsman Ice Machine - 290lb...
Scottsman ice maker putting black oily substance in the ice. What needs to be checked??
you need to call a refrigeration mechanic because the worm gear seals and transmission needs to be reseald.
Jan 24, 2014 | Scotsman Modular Flaker Ice Machine Water...
Scotsman ice machine problems
harvest thermo must not be working, or harvest cycle motor
Jan 03, 2014 | Kitchen Appliances - Others
I have a MV450 icemachine that work for up to 4 days without any problem .Then it cuts out the hi pressure indicator light up .i have checked the gas charge and cleaned the condensor
The magnetic switch just lets the machine know it finished a harvest and start ice production all over again. high pressure could be a dirty coil, fan motor stops working, a possible refrigerant restriction, or the room that the machine is in is getting to hot but this would cause the production of ice to take longer. it should be making ice every 15 to 18 mints in a 74 deg room.
Oct 05, 2013 | Scotsman Cooled Modular Contour Cuber Air...
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
I have some problem with our machine scotsman mv450 is to long product ice very slowly
Min freeze time 6 minutes and max freeze time 45 minutes. the 6 minutes is with perfect conditions. Example: Cycle time water temp was 50 degrees coming in to the water sump tray from water supply and the Ambient air temp surrounding the machine was a constant 70 deg than the machine should make ice every 10 - 12 minutes.now we know that the water temp from the water source is not going to be 50 deg and room temp will not be 70 deg all the time so the warmer water temp and ambient air temp is the longer it takes to make ice. one thing you wont to check is the water inlet valve to make sure it is not letting water seep through causing water temp not to cool down from running across evap plates. make sure the condenser coil is clean this will slow down production of ice.
Apr 17, 2013 | Kitchen Appliances - Others
Mv450 scotsman high pressure
Check to make sure the condenser coil is clean, fan motor is running during freeze cycle. High Ambient temp, Ventilation, The higher the temperature entering the condenser coil the higher the head pressure. Fan motor failure, pressure switch failure. The cut out pressure varies 400, 450 or 500 PSIG. Water supply failure. not enough water running over the evaporator plate will cause high presser.
Jul 30, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Problem with Scottsman Ice machine. Not sure of model, but about a 600lb. Refrigeration light is on (steady glow, not flashing), not making ice. Air filters on either side have been replaced with new...
wave your hand infront of bin eyes if the bin full light doesnt blink the machine is not reading the ice fall during harvest and will cause it to kick out. basically it thinks its not making ice.
Sep 18, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
Hello mate re mv450
Check the ice thickness sensor for mineral buildup and clean if necessary. I downloaded the service manual from a site in New Zealand. If the Ice thickness sensor is free of scale make sure you are NOT supplying the machine with soft water.
Let me know if this solves your problem. I have been servicing Scotsman Ice Machines for over 38 years in the US. I will try to assist you any way I can. This particular model is not sold in my country.
Jun 03, 2008 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs Logo
628 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
