Question about AudioBahn A8001DT Car Audio Amplifier
Audio bahn a 1800
I had a bunch of cloths on top of my amp and i smelled something burning and now my amp just jumps from protection back on making a thumping noise when it flips on for a second
  • 631 Answers
If it has cooled down and still goes into protect mode, it likely has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Oct 23, 2008
Amp fuse 30a keep blowing
You have possibly melted a couple of wires together along the radio circuit. Also the radio unit itself has 1 or more protection fuses actually inside the unit that have blown, usually at back of unit in little bay near the wire clusters.
Check your relays too, a blow out through jump starting can do all sorts of little burn-outs.
Oct 15, 2016 | 2006 Lexus Rx 330
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
I have two amps my power acoustic ov2-1800 stays in protect mode when i turn my car on, and my other amp is a JL Audio and it goes in and out of procect mode randomly??? Any insight???
You have a short. Check all power connections to both amps, all the way back to the battery. Then check to make sure speakers are connected properly
Jun 04, 2010 | Power Acoustik GOTHIC OV2-1800 Car Amp
Wire diagram for audio bahn AWIS12P
they are so many ways to run a dvc sub, let me know what ohms the coils are, and i will give you the ultimate bass that will hurt your hearing.
Feb 04, 2010 | Jl Audio DWC254 Mb Quart 10 Auto Bahn Car...
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
How can i get this amp out of protection mode?
You have a short circuit. I don`t know this particular piece of equipment but you should check all the output transistors/chips. Try disconnecting ALL the supplies to ALL the output devices and switch on, It should fire up, If it does, reconnect the positive AND negative supplies to one channel. If it still fires up, reconnect the next channel until you find the faulty channel then you could try doing comparison checks between the bad channel one of the good ones. These amps tend to use MOSFETS and are extremely intolerant to bad or loose connections. I hope this helps. You`ll probably find that you`ve got poor wiring, That will be your original fault. Ensure you make ALL connections good and sound before reconnecting the amp up with new devices in or you WILL be back at square one with no amp again. Ian
Jul 19, 2009 | AudioBahn A8001DT Car Audio Amplifier
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Protection Light On
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you didn't fry speakers as well. Please check speakers impedance. A thumbs up would be greatly appreciated if this answer is helpful to you
Nov 26, 2006 | AudioBahn A8000T Car Audio Amplifier
AudioBahn A8001DT Car Audio Amplifier Logo
149 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
