Question about Apex Digital PF2725 27" TV
Digital or Analog tuner
Does this tv require a digital converter box for antenna reception?
  • Ben Brewer Feb 15, 2012
    Cable provider has nothing to do with it. The signal is received thru the air with VHF/UHF antenna. Have been unable to receive signal to TV without going thru digital converter. Since TV says it is digital can't understand why.
    Top Expert:
  • Apex Digital Master
  • 75,311 Answers
Hello
Your Apex TV model have the tuner which is capable of receiving
VHF 2~13/UHF 14~69/CABLE TV: MID BAND(A-8~A-1, A~I)
SUPER BAND(J~W)
HYPER BAND(AA~ZZ, AAA, BBB)
ULTRA BAND(65~94, 100~125)
If the signal of your cable provider do not have in these ranges, you must have toconnect a converter.
http://www.dataentryjobs.us/67948.html
Posted on Feb 10, 2012
  • The Knight
    The Knight Feb 15, 2012
    Hello
    The tuner to your tV should be suspected, if it can't receive any VHF/UHF signals. Just test the TVs video section, by giving it analogue audio/video out of a DVD player, set the tV to AV mode, play any disc with the dVD player. See whether picture comes on. If it comes, make sure that the tuner to your TV has damaged. there is no repair to this unit, will look like a stell box. Replacement only can be done. OK.
4 Suggested Answers
thedayos
  • 57 Answers
SOURCE: Digital or not?
The model you bought IS digital. No box will be needed.
Need more help? Ask us at FixYa.com
Thanks
Len
Posted on Mar 10, 2009
TOM2-TOM2
  • 110 Answers
You will need a converter box with this unit.
Posted on May 26, 2009
SOURCE: Apex converter boxes malfunction.
If the converter box wont power on and makes a cyclic whinging noise, it may be one of the 4 470uF caps on the low voltage side of the power supply. Check for domed tops on the caps nearest the fly back transformer (center of the board). I replace all four of those caps just to be sure and it is playing fine now.
Posted on Nov 27, 2009
Is the Ematic AT103B Converter Box compatible with Suddenlink cable/digital service?
No, the Ematic AT103B is an over-the-air digital ATSC tuner and will also can convert the digital signal to analog NTSC for older TV tuners. It will not work with any cable service and is for "cord-cutters". The AT103B requires an antenna to receive your local OTA channels. Depending on where you live, you may get some channels with an indoor antenna. You will get better reception with an outdoor antenna. See http://www.tvfool.com or http://www.antennaweb.org for details on the channels you can receive with an antenna pointed in a particular direction.
The Ematic set top box does provide an HD signal output and a DVR (time-shift function) so it is more advanced than the first generation OTA converter boxes. The original (available with the government coupon) converter boxes only gave an SD output.
I hope this helps.
(antennaweb.org gives a very conservative list of available channels but assumes an external antenna. tvfool.com lists the channels that are likely to be received with a variety of antenna strengths. An antenna signal amplifier can improve the reception. (Digital stations will not be seen if the tuner can't lock onto the signal.) However, when the amplifier fails, you may find some channels will not be received at all.)
Dec 08, 2016 | Televison & Video
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
Does the JVC AV27230 require a digital to analog converter?
if you are going to continue using the rooftop antenna, then you will nee to purchase a digital converter box. Those television sets are only analog. You do have an option to get Directv or Dish network and you will not need a converter box at all. Directv and Dish network are 100% Digital and the receivers work as converter boxes for that product only.
Jun 16, 2009 | JVC AV-27230 27" TV
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Is my Hitachi 61uwx10b ultravision hd ready digital tv ready when they switch over to digital vrodacasting or will i need a converter box,
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
Jun 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Digital tv antenna reception
try googling how to build an antenna with coat hangers. not pretty but cheap!
Apr 08, 2009 | Insignia Digital-to-Analog Converter for...
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
Digital to Analog converter...no signal
One of the problems with digital reception is if the signal is not strong enough for the converter box/or built in tuner on a new TV- you will not get any picture at all. If you followed all the directions-and the converter box shows no channels- then you do need a better antenna. I don't know how far you are from the broadcast antenna, but a good rule of thumb is if you live 10 miles away, buy an antenna that is good for twice that distance, or further. They are rated in miles of reception
Jun 23, 2008 | Televison & Video
Apex Digital PF2725 27" TV Logo
141 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
