Question about Hoover Washing Machines
Hoover oph714d showing error code e07
Seems to be washing ok but at the end of the cycle it is showing code e07
5 Suggested Answers
  • 136 Answers
SOURCE: my washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Posted on Jan 18, 2010
SOURCE: Error message EC03 appears on cotton cycle after 5 minutes into wash
I found the basic instructions that came with the washing machine and found that you need a screwdriver to undo a screw to remove the filter cover. I then gradually released the filter cover to empty the water out of the machine in small quantities into a shallow tray. I was then able to remove the filter and clear it of 2 x 20p pieces and a load of gunk. I then removed the 'washable' floormat from the drum as the rubber backing from the mat was crumbling and probably not helping the filter. Filter cleaned and cover screwed back in, mat in the bin, and everything working fine since.
I did try ringing the customer support number and after pressing loads of keys to select appropriate options; confirming my address, postcode, name, date of birth, email address, mothers maiden name, what the kids had for breakfast etc, I was allowed to ask how to get the filter cover off. Apparently this is a technical query and would involve arranging an engineer to call. I declined this very kind service option and opted for a screw driver, common sense and a positive attitude. Worked for me! No blood shed, a tiny bit of sweat whilst trying to get through on phone, and only tears of joy when I fixed it all by myself.
Posted on Jun 02, 2009
  • 6277 Answers
SOURCE: Hoover H160E Washing Machine. At the end of each
First manual-
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Now a possible cause and cure-
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Good luck,
John C
Posted on Feb 28, 2011
  • 2006 Answers
SOURCE: error message e07 showing up
E07 is listed as a faulty door interlock switch or Jammed motor, please remember:
POWER OFF & PLUG OUT BEFORE CHECKING.
If you don't have the equipment or knowledge to safely check your machine, please call a good local repairman.
Posted on Jun 09, 2011
The machine shows E07 error upon entering the service menu.
Door latching or lock error
·Door not detected closed
·Check door is closed
·Check door catch and latch
·Check door lock wiring
Check door lock
Dec 11, 2015 | Blomberg Washing Machines
What is error code 7 on hoover wmh168d?
Louise, E07 means "Motor fault. check motor, tacho and associated wiring, check drum has not jammed" Presuming you can spin the drum by hand, I'd put my money on the carbon brushes in the motor being worn out and needing replacement
Sep 23, 2015 | Hoover Washing Machines
sorry but what can we do when there is no make or model listed we are not mind readers nor magicians
May 13, 2015 | Washing Machines
Error code E07 on my Hoover WDYN 854 DB results in me not being able to open door after a wash cycle any ideas how to open door
Switch off and for Door lock fault or Motor fault .
Check both are ok and make sure nothing is jammed or restricting the operation as it is according to which main board is fitted to the machine.
Feb 02, 2015 | Hoover Washing Machines
I have an error code E07 on my Hoover WDYN 854dB which results in me not being able to open the door after a wash cycle any idea how to open the door
make sure its drained 1st even drop hose to ground level which will gravity drain then door should open, could be blocked filter.
Error message e07 showing up on washer dryer model w856d Hoover
Jun 09, 2011 | Washing Machines
Hoover optima oph714ds error code e14
hoover optima oph 7d14 working ok but at end of wash cycle error e14 comes up what does this mean
Dec 24, 2010 | Washing Machines
Washing Machines Logo
792 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
