Question about HP OfficeJet Office Equipment & Supplies
How to clean HP Officejet K550 Printer waste tray
I was reading that before replacing the HP Officejet K550 Printer Heads the Waste Tray should be checked to determine if it is full or the rubber wipers are dirty. How do I perform this task of checking the Waster Tray and rubber wipers?
SOURCE: canon i350 printer waste ink tray full.
http://startcopy.ru/codes/canon_ip.htm
Good luck!!!
Posted on Dec 13, 2007
CAM THE MAN
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
SOURCE: waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
Posted on Dec 13, 2008
leroyal
  • 2120 Answers
SOURCE: Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Posted on Feb 05, 2009
SOURCE: waster toner tank full/not install
The Waste Toner Cartridge must be VERY clean, especially around the "bump" directly below the left side hole. After I CAREFULLY emptied the old toner out, I used air compressor to clean every bit of toner out from inside. Then I wiped the whole area around the "bump" where the sensor "sees" if the tank is empty. Even a slight film over the area will not allow for reuse. If you do this, it works every time.
Posted on Apr 06, 2009
My Office Jet Pro k550 won't pump ink from only one colour, the cyan. Will an HP cartridge help?
should, try cleaning the heads of the one that don't pump ink with achol and swab
Jan 26, 2013 | HP OfficeJet Pro k550 Printer
Wast Ink is Over Flowing
the waste ink tank is full.remove the unit and clean the old ink out and clean sponges.
Oct 26, 2012 | HP OfficeJet Pro k550 Printer
Magenta ink shows empty when full. have cleaned print heads, wiped off connection, run test pages- nothing helps
the copper detecter is gone bad..go ahead and contact HP they will replace the printer
Mar 24, 2010 | HP OfficeJet Pro k550 Printer
Iwant to clean out or change waste ink pad on epson r265 printer. have just used cotten buds to soak up waste ink to fix flashing lights. but i think only a temp. solution
Photo walk through here shows how to access waste pads
http://www.inkrepublic.com/KnowledgeBase/R260WasteInk.asp?C=0
Also shows how to replace with a bottle to collect waste ink
Feb 08, 2010 | Epson Stylus R265 InkJet Photo Printer
8550DP
That usually is a sensor failing. You can try to locate it (in the area where the tray goes) and see if it is loose.
Good luck.
Dec 13, 2008 | Xerox Phaser 8500/DN Printer
I cannot Print
Buy a differently branded printer. I have had the K550 for two years and have had nothing but problems, frustration and time wasted.All in all I have had in working for a couple of months at most. Numerous printhead cleaning exercises and paper thrashed. A tortuous waste of hours of my time (and I mean hours) trying to get it up a going. Each time I left teh printer idel for a couple of weeks, the whole printhead cleaning circus began again. Read the reviews on other websites. This model is a complete dud. Nothing can be done to salvage it. If still under warranty ask for your money back. Otherwise bring it to a recycling centre,
Aug 28, 2008 | HP OfficeJet Pro k550 Printer
My HPOfficejet Pro K550 will not print checks correctly
Hi crys smith -
for future refs: if the paper type and size (in this case checks) is set up correctly in the software that you are using to create the checks, perhaps it would help to check the printer settings. this link at hp support might help you then:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00494598&dlc=en&product=501369
it includes checking and changing print settings and stopping a print job. (-and no one wants to waste checks!) -JW50
Aug 26, 2008 | HP OfficeJet Pro k550 Printer
Tray selection
If there is such a thing for that printer it would be in the advanced settings under you printer driver.
Select control panel.
Select printers.
Move the mouse over to the printer.
Press the right mouse button.
Select properties.
Press the printing preferences button
Look under the advanced tab for the settings.
You could see if there is an updated driver on HP.com if that feature isn't listed.
Jun 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
mukhtar21 shaikh
mukhtar21 shaikh
