Question about Frigidaire Refrigerators
Adjust spring door closer on frigidaire commercial fridge
Model # FCR5201lFB5
2 Suggested Answers
SOURCE: Kolpak walk-in hinge adjustment
loosen the hinges slightly on door and door frame. Shim the door even in the door frame so its not touching on any side. Tighten hinge hardware and see if that helps. If it doesn't you are probably due for some new door hardware.
Posted on Oct 29, 2009
Door lift spring came off how to put it back on
the spring will be at the lowest tension when the door is in the raised position
there should be an adjustment at one end where the spring is attached to adjust the ease to lift the door and hold it open so if thee is loosen that adjustment off and with the door held up ,refit the spring
Oct 22, 2015 | Hobart Used AM14 Pass Thru Commercial...
How do I repair the door spring?
I believe you need to buy and install new door hinges.
Apr 21, 2015 | True T-49 Side by Side Refrigerator...
How do I adjust the springs on the door of a Frigidaire dishwasher Model # FDB24?
Springs run down both sides of the dishwasher from the door hinge to the back leg area of the frame at the bottom leg area. You adjust the spring/door tension but moving the spring to different holes in the frame area. Going one direction in the holes will loosen the door, going the other direction will make the door tighter.
Mar 26, 2015 | Frigidaire Dishwashers
How to adjust door viking dfsb423
Viking 42" built-in units usually don't offer any door adjustments. If one of the doors are not closing well, check for obstructions blocking the door bins, worn door gasket, and possible door warp-age on the panel ready models. Viking did have top hinge recalls updating to the new "Cobra" hinge on many of their models which can be verified by calling viking and providing your full model/serial numbers. If your Fridge door is lower than the freezer door you most likely have a worn door closer located on the lower hinge of the fridge door, the closer is a 2 piece plastic interlocking/mating unit which wears down over time from friction. This usually needs to be replaced. Pleazer Appliance...
May 06, 2014 | Viking DFSB423 Side by Side Refrigerator
Need a steel arm replacement part
adjust the backcheck. The pressure should increase as you get closer to the furthest point you want the door opened. You might consider a door stop as well.
Apr 01, 2014 | Global TC2203-DU Hydraulic Door Closer...
How do I change the door springs on my GST 40DF
We have a wide range of new hinges, door closers, and gaskets to help you get the correct seal & close for your commercial Turbo Air unit. We can even help locate the exact part you need just shoot us an email with your model and serial # and the part you need and we'll help make this process super simple! Coolergaskets.com
orders@coolergaskets.com
Aug 10, 2012 | Turbo Air Green World by 2 Door...
There are 4 adjusting screw on my door closer. Which one do I adjust for what? Instructions, please. Thanks.
Since this is under chain saws, it is hard to figure this out as a door closer.
It would help if you listed the make and model. Describing the adjusting screws might help as well. I can't tell if this is a hydraulic door closer or an electric garage door opener.
Feb 28, 2011 | Garden
Need more tension on door. added a aftermerket raise panel door kit. added weight to door is about 25 pounds.
Are you sure 25 pounds seems like a lot? Anyway take off the bottom panels under the door. UNPLUG FIRST! you will see the springs on each side usually you can adjust them tighter by moving the springs into slots/holes futher back towards the wall. If this won't work on your model, take a spring off and go to your local hardware store and buy new springs that are shorter or have more tension.
Mar 23, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Frigidaire refrigerator model #FRS26R4AW7 is freezing up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 03, 2009 | Frigidaire Refrigerators
Door closer pin
You can make one or order one through "Coldparts.com" if the part is available individually.
Apr 30, 2008 | True T-49 Side by Side Refrigerator...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
