Question about Goodmans W280NS Television
Goodmans 26inch model ld2666d
Picture is black and white when connect xbox 360 or a wii but works fine with a ps2 tried scart and av connector problem still there tv is only 1 month old
3 Suggested Answers
SOURCE: Sony KLV-26U300A + xBox 360 setup help needed!
SHEARCH eeprom memory dumps
Posted on Jun 21, 2009
  • 6 Answers
SOURCE: My goodmans TV/DVD model GTVL19W17HDVF about 18
Have you tried unplugging the unit, and waiting for 5 minutes and then restarting from the FIRST TIME setup screen. If you do that and then get a can of liquid air cleaner spray and blowing the area inside the slot with the cleaner and then reloading a disc that you know works. If this does not work then the reader transport mechanism is probably pooched
Posted on May 12, 2010
I have a jvc i'art tv. model # av-27f476. i have an xbox 360. how do i hook em up? i have plugged the red, white, yellow cables to the corresponding colored jacks on the front of my tv. i turn my xbox 360...
on the xbox i think the hd works with all 6 cables connected so you will need to switch it back to standard definition. if its still not working try it via scart m8
Mar 06, 2010 | Video Game Consoles & Games
No pic with Logik 19" and Xbox 360
Your console has the RROD, it needs to be reflowed by a PROFESSIONAL, not some kid with a heat-gun!!! It is IMPOSSIBLE to repair a BGA with a heat-gun!!
Nov 22, 2009 | Zenith B25A02Z TV
Xbox 360 won't show cuz of s-video
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the AV PORT is faulty or its your cables..
Mar 06, 2009 | Microsoft Xbox 360 Arcade
Plug in the wii system and everything comes in black and white
Try plugging it into another scart socket, this sometimes happens when a tv does not support 60hz. the result is a screen that has no colour. You could try just plugging it onto the seperate av inputs. Most tv's these days have one scart that will work ok and in colour.
Jan 18, 2009 | Nintendo Wii Console
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
My xbox360 does not show any color
if this has only just happened and everything was fine before then try another av lead, or if you have a connection at the front of your tele to plug the red yellow and white av leads into try this instead of a scart connector
Oct 24, 2008 | Microsoft Xbox 360 Console
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
Televison & Video Logo
111 people viewed this question
Top Goodmans Televison & Video Experts
Kolbrun...
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
