Question about Whirlpool Dishwashers
How do i drain whirlpool Dishwasher model number DU920QWDB3
4 Suggested Answers
TheMazz
  • 78 Answers
SOURCE: whirlpool dishwasher won't drain? Model#DU5000xw
When it is suppose to be draining, do you hear the pump running.
If not, then the pump or controller/timer is bad. If the controller is sending power to the pump and the pump doesn't run, it's the pump. If no power is getting to the pump, then the controller is bad.
You'll need a voltmeter and know-how to diagnose this electrical problem. This is high-voltage power with water in the area. So please don't try to use a voltmeter unless you are confident of your skills.
If you do hear the pump, then the drain valve (solenoid) is the problem.
The solenoid valve and the pump are all underneath the unit. Accessibility from the front, bottom panel.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Posted on Oct 13, 2009
reg501
  • 413 Answers
SOURCE: Whirlpool Gold Dishwasher not moving water
The wash motor has probably froze up.
Posted on May 29, 2008
docjohn174
  • 943 Answers
SOURCE: I own a whirlpool undercounter
hi did you take the drain hose off at the sink or off at the motor if not at the motor then check the motor drain hose thanks the appliance doc
Posted on Sep 27, 2008
My Whirlpool Dishwasher dose not drain. MOD# WDF520PABO
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Dishwasher.
Feb 21, 2017 | Whirlpool Dishwashers
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Whirlpool du810
There should be a check valve in the drain hose to prevent that.
Is the sink drain clogged?
Link to video showing how to replace the drain hose and check valve. Dishwasher Repair Replacing the Drain Hose and Check Valve Whirlpool...
DU801 is not the complete model number. Find the complete model number. It should be just inside the door on the right side of the tub.
Go to sears parts direct. And enter your model number and find the part number for the drain hose of your dishwasher. The number in the video may be the correct one.
Link to searspartsdirect.
http://www.searspartsdirect.com/
Sep 06, 2014 | Whirlpool Dishwashers
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Won't start/run. CLEAN light blinks continuously. manual drain (CANCEL)button works model number DU1100XTPQ9
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
The manual for the DU1100XTPQ9 is here: http://www.managemylife.com/mmh/owner_manuals/4164/WHIRLPOOL-Dishwasher-L0704454?brand_name_search=DU1100XTPQ9+WHIRLPOOL . Various parts diagrams and links to purchase the parts are here http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPQ9/1198/0130000 .
I hope this helps.
Jun 20, 2011 | Whirlpool Dishwashers
Whirlpool dishwasher will not drain. If the motor is tied into all fill and drain functions then the motor is good. I removed the drain hose and primed it with a total clear line I am in the dark.
here is the schematic for your entire machine http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-GU2400XTPT7/1198/0130000?searchedModel=GU2400XTP&blt=06 have you check the drain pump which is seperate from the motor? the motor basicly runs the sump with water going on the inside of the machine the drain pump is drains out the water part number 17 in this next diagram if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks again Rick
heres the pump and motor section link http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0512156-00008.png
Feb 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Water not draining in bottom of dishwasher
it might help to know the full model number of the dishwasher.
if the drain motor can be heard at the end of cycle and yet no water is draining out, then there could be a blocked drain hose or kitchen sink.
if you cannot hear the drain motor operating then it is a likely blockage or fault in the drain pump/ motor.
Jan 07, 2011 | Whirlpool Dishwashers
Whirlpool disher
Run diagnostic by pressing Normal, heated dry, normal, heated dry, normal heated dry. a total of 3 times in 15 seconds.
The dishwasher will reboot and run a test load.
Nov 15, 2009 | Dishwashers
My Whirlpool dishwasher will wash fine, but when it drains, it's a slow trickle. I've snaked the line from the sink to the washer, but I can't find a clog. If I try to blow into the drain pipe all I...
Ok, don't fret too bad, help maybe just reading.
Disconnect the drain hose from the sink/garbage disposal, get a big bucket, stick hose in bucket, making sure that end of drain hose does not get lower then the bottom of dishwasher. Turn dishwasher on (to drain mode if possible or just wait for drain mode) and see if water drains like it is supposed to, if not (and drain hose is not blocked with grease) then either drain solenoid is bad, not opening drain trap all the way or your drain pump is defective.
Did you just replace the garbage disposal, common mistake when replacing disposals is failure to remove dishwasher drain plug knockout.
If further assistance is needed, give us the model number of the dishwasher so I know what model I'm working with.
Oct 01, 2009 | Whirlpool 24 in. DU1055XTPS Stainless...
Dishwashers Logo
51 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
