Question about SanDisk Sansa e250 MP3 Player
E250 won't turn on
  • 536 Answers
Try resetting the device by pressing and holding down the Menu button for 15 seconds.
If that does not resolve the issue, then you may need to replace the battery in the device.
Posted on Feb 10, 2012
Why won't my Sansa 250R won't recognize an sd card?
Your 4GB card is actually a microSDHC card. The e250 works with microSD cards, 2GB and smaller.
Mar 10, 2013 | SanDisk Sansa e250 MP3 Player
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
I have 2000 e250 5.4 won't rev up changed mas and throttl sensor fuel psi 28 to 45
Did you check for trouble codes ?
Sounds like the TPS is not connected to the computer.
Sep 06, 2012 | 2002 Ford E250
Sansa e250 mp3 player won't recogize micro card
Make sure the card is a microSD card, not a microSDHC card. The e250 only works with microSD cards, 2GB and smaller.
Mar 19, 2012 | SanDisk Sansa e250 MP3 Player
Videos won't synchronize from windows media player to sansa e250 mp4 player
You need to use the supplied Sansa Media Converter program to convert videos (and photos) to a format the Sansa can handle. If you don't have the SMC, you can download the Windows version here.
Mar 19, 2012 | Audio Players & Recorders
I have 94 e250 5.8L van 4x4 and it won't turn over
Hi Nick:
You wll have to pinpoint what the engine is missing...
- Spark
- Fuel
- Compression
All three of these are tested when the engine is being cranked over. There are two way of checking for fuel. Fuel pressure and fuel trigger. Both are very important and must be present for the engine to start. Fuel pressure is self explanatory. You just hook up the gage and see what the reading is. Fuel trigger is check with a noid light. The injector gets unplugged and the noid light gets plugged in to the injector clip. With the engine cranking over, this light must blink. This is the signal to the injectors from the computer. You can have all the fuel pressure in the world, but it wont matter if the injector is not pulsing gas into the cylinder like it should.
Compression tester, spark tester, fuel pressure gage and noid light are all accessible at your local auto store. All three tests play a very important part in diagnosing a no start condition. Be extremely careful when doing these tests.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 09, 2012 | 2002 Ford E250
Ford e250 brake lights stay on
If the lights only stay on when key is in ignition, your central brake lights (or one of the lights) are out. The other lights stay on as a warning that the centrals(or other brake light/s) are needing replaced.
Feb 07, 2012 | 2003 Ford E250
Won't turn on
Please give some more details.
I suppose it's the problem that your Sansa e250 MP3 Player won't turn on.
You could turn to Sansa official support.
Jan 03, 2012 | SanDisk Sansa e250 MP3 Player
Ford 2004 e250 after cleaning/removed battery terminal, won't start or engine won't running, fuel 1/2 full, this happen after disconnect +/- battery terminal remove.
If you indeed installed the positive battery cable last and the neg first you blew the computer possible, you will need a complete diagnosis.
Jul 01, 2011 | 2004 Ford E250
SanDisk Sansa e250 MP3 Player Logo
51 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
