Question about Proform 730 Folding Treadmill Model PFTL71104 - !
I have a pro form air stride 730si treadmill, it keeps displaying an error
  • 64 Answers
SOURCE: display works, treadmill doesn't
Motor controller.
Posted on Jun 08, 2009
SOURCE: Pro Form treadmill display lights up but the
Check out The treadmill Doc. Fantastic site and great people to do business with. A lot of helpful trouble shooting information for free! I'm betting it is the motor control board. Site will lead you through step by step instructions to check and fix it yourself. I saved a ton of money and with a little know how and good information you can too.
Posted on Dec 16, 2009
  • 43 Answers
SOURCE: treadmill not working properly. Incline keeps slipping.
there is a plastic spacer at the rack area on the incline mtr- this white plastic spacer has broken, only recourse u have is to unplug the white wire on incline mtr, and never have a incline, or replace incline mtr when you find out how much the mtr is you might want to walk with out incline- if you was in my area, I have them cheaper
Posted on Jan 08, 2010
  • 246 Answers
SOURCE: i have a pro form cross walk advanced 525x when i
the treadmill should have tension adjusting screws. they'd be on the back of the treadmill where the belt wraps around the rear roller, they're inset and you'll need an allen wrench to adjust them. the screws adjust this rear roller. you'll want to tighten them to increase the tension. they also straighten the belt. if your belt is too fat to the right, you'll want to turn the adjustment screw on the right clockwise to tighten and this will bring the belt over to the left. and vica versa for the belt being too far to the left.
Posted on Feb 18, 2010
maxtreadmill
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
Treadmill pro-form 705 not starting
All that I can think of is to check that the motor is getting power.
Sep 19, 2012 | Proform Pro - Form Treadmill 705 CST
I have a Pro-form 730si treadmill. When I turn it on it starts to run then begins to pulse then shuts off. What is my problem?
Dear Sir:
Hello , I hope everything is o.k
I will give some tips:
1) The problem will be in electrical problem: a)If the circuit breaker is tripped after your turn on  , reset b) if the problem continue ,you must inpection the power cord, for to short, or cut and replace, you must use DVOM(Digital Voltimeter) for measure continuite and to get exact response. c) if the wire is o.k, inspection the outlet box, measure voltage with DVOM, for to read exactly Voltage according to plate the machine 115vca or 22ovca. If not o.k check the circuit breaker from the panel Home, and repair. d) Finally the power supply in the PCB will be faulty, some wire loose, or some component is the board: condenser, resistor, diode, transistor is in Short-Circuit REPAIR.
Thank you in advance, sincerely. Blessing. If you need additional assistance, please contact me.
E.Cuadra Managua, Nicaragua.
Sep 26, 2011 | Exercise & Fitness
A friend of mine gave me her old Sears Pro Form Space Save 730 SI Treadmill..I was able to use it twice and for some reason I cannot start it...It lights up but does not move...I do not have a Manual..Is...
hi,
I have the manual of Pro Form 730si . If you can give your email as a replay for this then i will sent the manual to your email id. I can't upload the manual through fixya. Because its a pdf file.
OK
Sep 18, 2011 | Proform Exercise & Fitness
Describe how to unfold a treadmill, pro form ex
May 31, 2010 | Proform Exercise & Fitness
I have a pro form cross walk advanced 525x when i jog on the treadmill the track will stop rotating mid stride
Feb 18, 2010 | Proform Crosswalk 500 Treadmill
Treadmill not working properly. Incline keeps slipping.
Jan 07, 2010 | Proform Quick Burn Pro Treadmill with 12...
I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Jul 14, 2009 | Exercise & Fitness
Proform 730 Folding Treadmill Model PFTL71104 - ! Logo
60 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
