Question about Dryers
ZANUSSI TUMBLE DRYER TCE 7227 W. MAKING A TERRIBLE WHIRRING NOISE.
The dryer appears to be working apart from the awful whirring noise when the drum spins. i was wondering if something has slipped or been knocked out of place during a recent move. How do i get into the dryer to see if there is anything i can do? Does anyone think that i will be able to solve this without calling out an engineer?
4 Suggested Answers
  • 1073 Answers
SOURCE: Whirring noise in clothes dryer
check rear tub rollers and also check the idler pulley
Posted on May 12, 2008
  • 57 Answers
SOURCE: Tumble dryer not working
sounds like a broken belt ;it has to be un plugged from the power source . most belts can be accessed thru the panel on the back o f the dryer.
Posted on Jun 12, 2009
dragonsthatk
  • 547 Answers
SOURCE: zanussi td4112w drum stopped spinning
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Posted on Jun 19, 2009
Whirlpool Cabrio Dryer MOD WED5600XW0 making whirring noise
take the bottom panel off,you'll see a metal duct that the lint filter slides down into,there's a blower wheel behind the duct,if the wheel cracks or gets loose where it connects to the motor shaft it can make this sound,start the dryer and listen to see if the noise comes from there.if you can't tell unplug the dryer,pull out the lint filter and then take out the screws that hold the metal duct in place and remove it,now you can see the blower wheel,spin the drum by hand and see if the blower wheel moves with the drum and belt.if it looks fine stop spinning it and grab the wheel and see if it feels loose,if it is you will be able to tell.also while you have the duct off clean it out,you should take it off at least once a year and clean it out,then vac out the cabinet and blow out your vent line with a leaf blower if it's long,just remove it from the back of the dryer,stick a leaf blower into the vent line and blow it out.go outside first and make sure the outside duct is clear,no cage or anything that will block the lint from blowing outside.if the blower wheel is ok then the noise could be the belt roller or belt pulley,thety sell a kit with all the parts together but usually when someone says it's making a whirring sound it most likely is the blower wheel.hope this helps.
Nov 13, 2013 | Whirlpool Dryers
My whirlpool tumble dryer is making a whirring noise but not spinning but when i turn the drum by hand it works as soon as it stops i need to turn the drum by hand again can any1 help?
It may be the belt attached to the drum has either stretched or is worn. You'll have tio remove the front panel but as you do, tre whole drum drops. Careful. Having extra hands available, helps. Check belt to see what's wrong.
Jan 15, 2013 | Dryers
Really loud whirring/squealing noise
Yes, It is still safe but very annoying...
The source is probably the guide rollers for the drum or the belt tensioner pulley. To know for sure you will need to pull the dryer apart and turn it by hand slowly and see where the noise is coming from...
Heatman101
Mar 03, 2010 | Whirlpool Dryers
TCE 7227 W tumbledryer waterconductivity needing regular restting
Carolsquires, I have the same problem with 7227, did you get a solution?
Trevor
Feb 17, 2010 | Zanussi Dryers
Kenmore 11066812694 dryer whirring noise in back
Could be the rollers holding up the drum, or the motor blower fan.
Jan 18, 2010 | Washing Machines
Zanussi td4112w drum stopped spinning
Jun 19, 2009 | Zanussi TD4112W Electric Dryer
Jun 12, 2009 | Dryers
May 11, 2008 | Dryers
Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
