Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. It could be as well a defective or a malfunction pump. Let me know if you will need for further assistance. Good luck!
Hi i have a Indesit IDL 530 dishwasher. The 2 green lights - Number 1 and 3 are flashing. The manual...
(More)
Hi i have a Indesit IDL 530 dishwasher. The 2 green lights - Number 1 and 3 are flashing. The manual indicates the filter is blocked. But having checked the filter all is ok. The drain pump works fine. Any help?...
when using the tablet disspencer the door does not open during its cycle therefore not dissolving...
(More)
when using the tablet disspencer the door does not open during its cycle therefore not dissolving tablet or washing dishes?
dial turns as if it is going through cycle but washer does not operate and it makes a low whirring...
(More)
dial turns as if it is going through cycle but washer does not operate and it makes a low whirring noise
