Question about Tools & Hardware - Others
How do i replace brushes on porter cable model 7539 plunge router
  • 885 Answers
The brushes are on the front and back of the motor, under the top cover. Remove the four screws on the top cover and remove it. The brushes are held in place by a coil spring, pull it back so the brush will slip out. Some brush leads have slip connectors and others are held in place by a screw, depends on what type router you have. Disconnect the brush lead then reverse the process to install the new brush.
Posted on Mar 10, 2012
  • 22 Answers
SOURCE: Manual
check the web sit , ace tool repair.com They have free acess to these. manuals
Posted on Dec 13, 2008
rowdy45176
  • 2176 Answers
SOURCE: router runs slow
I still think that it is the bearings, especially since of the squealing noise which is a symptom of the bearing seizing up and the armature shaft would get hot transferring the heat to the motor housing. Give me the model number and brand and I will find a breakdown and part numbers for you and also if you give me your general location I will try and find someone local to get the parts.
Posted on May 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: where can I get a 1/4'collet for porter cable
I show the part number as 42999 for the accessory and they also list 876669 for the 1/4 collet. Give me the general area with zip code and I will try and find someone locally that can help you
Posted on Jul 01, 2009
mtatham
  • 13 Answers
SOURCE: how do I disassemble a porter cable 1002 router
How do I hold the armature still on a Porter Cable Model 1002 Router to take the nut off to change the inner bearing
Posted on Oct 13, 2009
rowdy45176
  • 2176 Answers
SOURCE: How difficult is it to replace a fan in a 7518
it has to be pressed on and off the armature shaft, Also unless there is a retaining ring or other stop it needs to be set to a certain depth so it wont hit the housing. I would try and see if there is a repair facility that can do this work for you, the cost I would think would be minimal
Posted on Oct 30, 2009
What is gmc sierra 1993 4.3l firing order?
All chevrolet/GMC 4.3L engines from 1990 thru 1995 had the same firing order.
That would be 1 6 5 4 3 2
Jul 16, 2014 | Porter Cable Porter-Cable 7529 Factory...
Loud whinning 7539
Noises like that are usually a bearing going, or gone, bad. If you keep running it eventually the alignment of the armature will be off enough to make contact with the field and one or both will get damaged enough to warrant replacement. Bearings run between $7 to $15 to replace. Armatures are $175 and Fields are $110 for your router.
Feb 09, 2012 | Porter Cable Tools & Hardware - Others
Porter cable 7538 router manual
you can try going to dewaltservicenet.com and under manuals on the lefthand side of the site type in your model number, it will redirect you to another page for manuals.
Dec 08, 2011 | Porter Cable 3 1/4 Hp Plunge Router
I'm trying to find an owners manual for Porter Cable 6931 TYPE 1 Plunge Router . can you please asisst me?
you can try going to dewaltservicenet.com and under manuals. Let me know if you need more assistance.
Jul 29, 2011 | Porter Cable 8901 Router
My 12 year old plunge router 7529 does not start. It worked just fine a couple of days ago and all then sudden... nothing. Any suggestions!
A 1 year old router...that suddenly stops working. My suspicions would be brushes first then the switch.
There are 3 different types of this router Type 1, 2, and 3.
Parts can be found here:
http://www.ereplacementparts.com/porter-cable-7529-type-plunge-router-parts-c-129_1672_1985.html
Brush is item 3 and switch is item 4.
pdf of diagram: http://www.ereplacementparts.com/images/Porter_Cable/7529_TYPE_1.pdf
Thanks for choosing FixYa,
Kelly
Kelly
May 11, 2011 | Porter Cable Garden
Plunge router is stuck in the router base. Porter Cabe 891 router is stuck in the plunge base. Released the buckle and won't come out. What to do? Thanks, Joe
If you are talking about the nut tap on it with a hammer, if you are talking about the tubes you can try cleaning them with air and then using some lubricating fluid to free up the piston/springs. Let me know if you need more help
Mar 15, 2010 | Porter Cable-Cable 891 2 1/4 Peak HP...
How do I disassemble a porter cable 1002 router? I am trying to get to the motor in order to clean out pieces of broken brushes.
Oct 14, 2008 | Porter Cable Tools & Hardware - Others
How to adjust the collet easily?
Look for a button that will lock the collet in place. This will allow you to adjust the collet with a single wrench, without having to wrestle with several wrenches.
Aug 27, 2008 | Porter Cable 75300 Height Adjustment Knob...
Tools & Hardware - Others Logo
123 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
