Question about HP LaserJet 3330MFP All-In-One Printer
HP Laserjet 3330mfp - Printing dark pages
I am trying to fix a used HP Laserjet 3330mfp. Scanner works good, but, the printer is printing pages that have 7 dark lines across it and it's pretty dark in the middle top to bottom.
SOURCE: Dark Background on HP Laserjet 4100
Several Options:
- Increase the Toner Density Level to 5
- Use freshly opened media
- Use a new print cartridge, if near end of life
- Run a cleaning page to clean the fuser
Posted on Jun 19, 2008
pdouglasss
  • 125 Answers
SOURCE: Hi My LaserJet 3330mfp
You may be having a problem with the cleaning blade that is in you toner cartridge. You will have to replace the toner cartridge.
Posted on Jan 08, 2009
SOURCE: HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Posted on Apr 08, 2009
  • 313 Answers
SOURCE: hp laserjet printer is printing a large vertical
if the band is white, you may have a problem in your laser scanner assembly, if the band is black, you may have a problem in your fuser assembly
Posted on Mar 31, 2010
tballone
  • 126 Answers
SOURCE: My hp laserjet 3330mfp reports
Here is how to cold reset the machine. also I added some addtiona options below as well.
1 Unplug (or turn off) the product from the power source.
2 Press and hold down the * and menu/enter keys.
3 Continue to hold down the keys while you plug back in (or turn on) the product, through the entire power on sequence.
4 When the control panel display reads Permanent Storage Init. release the keys.
5 Allow the product to return to Ready before using the product.
If that doesn't work it can be a power related issue,
- Make sure it's NOT plugged in to a surge protector.-
- Try a different outlet on the wall.
if theses steps fail you will most likely have to replace the scanner assembly
Another Option you can try as well :
Also I found this on a HP forum NOT SURE IF IT ACTUALLY WILL WORK:
" Scanner Bulb Walkout - Unplug the power from the unit,plug the power back in wait until the unit reads "Scanner Bulb Warming Up" Unplug the unit. Repeat this step 5 times.
This should move the scanner assembly back to its home position.
link to this post : http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=989123
Posted on Oct 20, 2010
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
HP Laserjet 6L Dark Printing
Check your Toner, and also the thermal roller of the printer..
Thank you
May 29, 2008 | HP LaserJet 6L Printer
Printing too light
For understand the issue, little bit technical knowledge required: Take half test page, check how much dark image formed on paper, check on cartridge drum how much dark image created?..(half test page: while printing half of the page switch off the printer, take cartridge out as well as take half printed page)If half page print quality is good on paper: Fuser faulty(teflon sleeve)If half test page print not good & image on drum is OK: Fault with Transfer roller or its bios voltage contacts..If there is proper image on paper & image drum: Problem with laser scanner assembly..find the problem, then remedy is easy..
Feb 02, 2012 | HP LaserJet 3030 All-In-One Printer
The scanner bulb goes back and forth about an inch in hp 3330 prt
The scanner blub mirror needs to be cleaned and possibly the underneath side of the scanner glass. The scanner is not finding the marks to make it function correctly.
May 15, 2009 | HP LaserJet 3330MFP All-In-One Printer
Hp Laserjet 4 Plus printing very light - second post
Your description indicates that the problem is with the printer driver settings.
Go to Start, Control Panel, Printers and check the setings for Economode and ReT. The should both be off or Economode=off and ReT set to Med or Dark.
This should fix the problem. Let me know if this works or not and we can try something else.
May 03, 2009 | HP LaserJet 4m plus Printer
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
Several Options:
Jun 18, 2008 | HP LaserJet 4100 Printer
Fax confirmations printing dark
change the toner cartridge , if it doesn't solved your probleme then it is probably that you have a defective Laser/scanner ( turning on laser continuously )
Jan 09, 2008 | HP LaserJet 3330MFP All-In-One Printer
HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
Dec 31, 2007 | HP LaserJet 1320 Printer
HP LaserJet 3330MFP All-In-One Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
