Question about LG 32LC2D Television
Lg lcd tv makes screeching noise when i turn it on
We have had this tv for over 3 years and it has been really good. Yesterday I turned it on and it made a really loud screeching noise. I turned it off again, waited and switched it back on. This time no screeching noise, but also no sound on the tv. After a few minutes the sound came back on the tv. All fine. Today again, switch tv on, screeching sound, turned off and on again, tv comes on no sound, but now the sound has just not come back. switched off, and the screeching noise is back.
  • Lisa Feb 12, 2012
    occassionally we switch it on and it works totally fine. Another time we get the screeching, if i leave it screeching long enough the noise goes away. The screeching cannot be turned down with the volume or mute button. The picture is unaffected. Once the screeching stops, we have perfect picture but no sound, then after a few minutes the sound comes on and all is fine. We can watch tv normally then for anything from half an hour to a couple of hours until the volume will just disappear altogether again, and we have to wait anything from 5 minutes to all day for it to come back on.
SOURCE: LG TV
There is probably a bad capacitor on the power board, I had the same thing happen to my 42LB1DR after 2 years. T.V. would turn on and white power light would blink, no pictue and no sound. If your'e a diy'er, it is not that hard of a fix. Take all the covers off of the back of the tv(UNPLUGGED!!!), then look at all the capacitors on the power board. lcd_repair_4_bad_capacitors_lg.jpg
These are the capacitors, look to see if any of them appear to have a bump on the top of them. They are supposed to be flat, you can also tell if one of them has gone bad if there is an oily substance on the metal cover that was removed. If one of them is in question, carefully remove the board, and take it to an electronics store to have them sotter ?sp on a new capacitor. It ended up costing me around $40.00 to have this done. Good luck and if you are not comfortable trying this, than take it to a repair shop, but I was quoted around $450 to take the T.V. in. No Thanks
Posted on Nov 21, 2008
SOURCE: 42 inch LG Plasma TV - Lost picture
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
SOURCE: LG 32'' LCD TV aspect ratio self switching
Not a real solution actually. The store where I purchased the TV changed mine with another one...
Regards,
Massimo Moruzzi
Posted on Nov 30, 2008
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
  • 13 Answers
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Posted on Apr 28, 2009
My dryer is making a loud screeching noise when I turn it on, it is only 3 years old.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 29, 2010 | Whirlpool WED9200SQ Electric Dryer
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
My ps3 makes a loud screeching noise when i turn it on
Its just dirty, clean it the best you can and make sure it has space to breathe
Nov 04, 2009 | Sony Playstation 3 (PS3) Console
Loud buzzing noise which became a very loud screech over the last week. Turning tv off and on seemed to remedy it. Today screen was only black and white, now no video only audio. Is this the picture...
This TV uses a lamp and color wheel. the color wheel is likely the problem since it is known to make noise over time and will eventually sieze. The repair is in the $400 range.
Sep 27, 2009 | GE 46GW945 46" Rear Projection Television
Screeching noise coming from driver side tire
The high pitch sound may come from the brake pads as metal parts hit the disc to signal the owner that it needs change. The metal parts gets exposed when the pads have worn out. The brake also has a hub to cover the disc. See if the metal plate is hitting it but this issue would appear when the wheels are in motion. Check if it is the belts, have the tension checked out. Other than that the bearings are the other items on your wheel that could cause a high pitched sound when you car is in motion.
Aug 09, 2009 | 2005 Dodge Neon
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
Televison & Video Logo
452 people viewed this question
Computer Repairing
Computer Repairing
