Question about Ricoh Aficio SP C222SF All-In-One Laser Printer
Waster toner bottle
Near end waste toner bottle
jaylex
  • 417 Answers
SOURCE: We removed the waste toner bottle and it won't reset the error message
You will need to vacuum all the toner out as in the machine there is a sensor that looks through the waste tank and checks that it is clear. You can also wash the tank out then install it and you will not have the problem.
Thanks J
Posted on Jan 28, 2008
SOURCE: Where is the waste toner bottle in a ricoh 4000
Left Side panel.
Posted on Feb 19, 2009
SOURCE: can you resue a waste toner bottle
Change the waste toner bottle. :-)
Posted on May 14, 2009
SOURCE: how do I change the waste toner bottle for a ricoh sp c410?
Drill a 3/4" hole in lower left side of waste toner bottle. Waste toner is very fine and will get all over the place – you also may want a breathing mask. Take outside and dump waste in large ziplock bag and dispose properly. Put a large piece of shipping tape and cover hole. Put back into ricoh c410. This wi;; save you about $50 and less plastic in our landfills. SG
Posted on Jul 23, 2009
SOURCE: Waste toner is almost full on Ricoh aficio AP3800C
Open the main front cover and you will see the white plastic waste toner bottle on the left hand side halfway up. I lies on its side and you can see the bottom of it.
Slide it out gently keeping it level to avoid spilling all the waste toner.
Either replace with a fresh empty waste bottle or empty the bottle into a large plastic bag you can keep sealed with the bottle inside while you shake it.
You have a good chance of spilling the toner all over your clothes if you are not carefull and note that the waste toner IS HIGHLY INFLAMMABLE so no naked flames nearby!!
Posted on Aug 01, 2009
Where is used toner bootle dsm 635
it has not waster toner bottle on the machine, the waster toner is being recycled in the photo-conductor unit (PCU) so if the machine show replace the waster toner bottle just clean the PCU of the machine on the drum upper area
Sep 21, 2015 | Gestetner 3532 4532 Dsm635 Dsm645 Toner 4...
I've replaced the toner cartridge and waste toner bottle, but the display still says 'toner low' and 'waste toner near full'. It refuses to print, even with the old cartridges.
Then you mite want to clean the sensor that monitor the waster toner box pull out the waste toner box and look for the area that show clear plastic then look for those area of the machine and blow the old toner from those areas waste toner mite have gotten on the sensor saw they can not see the clear plastic and think that the waste toner cart is still full.
Sep 09, 2014 | Konica Minolta Magicolor 5670EN Color...
I have a Canon Image Writer 2020. I am geting an
waste toner is full.replace the whole drum unit
Mar 03, 2010 | Canon imageRUNNER 2000 Copier
My samsungclx-3160 all in one is asking me to replace/install waster toner tank?? it wont print now whats that
The waste toner tank may be full. Please open the front cover( where the toner bottles are located).
You will find a transparent "L " shaped box is the waste toner tank.
You may pull it out and replace it.
Oct 23, 2009 | Samsung CLX 3160fn All-In-One Printer
Waste bottle full...can i empty it and how??
Don't be conned out of your money by Konica or any salesmen. The waste bottle can easily be emptied. There is no sensor that 'gets tripped and can't be reset' this is bull*&%t. Just take the cartridge out. Go somewhere that you can dispose of the toner (make sure it's not windy !) then turn it to the 'locked' position. This opens the port, then just shake the thing back and forth for a few minutes. You can feel getting lighter. Then turn back to unlocked. Use a vacuum to remove toner from outside of cover, then a soft cloth or wipes to get it clean. Then put it back in.
Jul 21, 2009 | Konica Minolta magicolor 5430 DL Laser...
I have Canon ir5075 and it asks me to change waste bottle. I empty the bottle. But do not know how to tell the printer that it is empty.
I am not familiar with this model but usually Canon waste bottle has:
1. Check if the waste toner botlle has some clear portion near the neck, (as in IRC3200) or other part of the bottle ,even the waste toner was removed but if this portion is still clouded by toner the sensor will still detect the waste is full
2. If the situation is not like this some Canon Ir machine needs to reset waste toner counter in the service program mode even the waste toner bottle was emptied
Jun 09, 2009 | Canon imageRUNNER 5000 Copier
USED TONER CASE IS NEARLY FULL
Hello sir; There have no waste tone bottle for this machine, but waste toner all stuck in the imaging transfer belt unit, on the right hand side door,pull it out dump the toner out and vaccumn it.
May 06, 2009 | Ricoh Aficio 450 Copier
My Kyocera Mita KM-C380 copier check waster toner tank
Hello sir; the waste toner tank haveto be clean up thoroughly, aspecial the bottle neck .
Mar 30, 2009 | Kyocera Mita Office Equipment & Supplies
How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Aug 27, 2008 | Xerox DocuColor 3535 Copier
Waste: near full
take the waste bottle out & empty it. I have never had to buy a new one.
Aug 30, 2006 | Konica Minolta magicolor 5430 DL Laser...
Ricoh Aficio SP C222SF All-In-One Laser Printer Logo
62 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
