Question about Sewing Machines
Singer confidence sewing machine bobbin
This machine is only 8 months old, and I have used it sporadically, without any problems. Suddenly, the bobbin thread is not being picked up, and the machine is not sewing. I followed the troubleshooter instructions to recheck the threading, remove the face plate and dust the feed dogs and surrounding area. Despite the machine being set to default straight stitching when powered on, the needle appears to have a lot of lateral movement, and makes a scraping sound each time the hand wheel is turned. Any ideas.
  • Sewing Machines Master
  • 7,365 Answers
Have you tryed changing the needle--flat side goes to the back of the machine--if that does not help it's also possible that the machine could be out of time
it would need to be serviced
Posted on Feb 10, 2012
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
  • 22 Answers
SOURCE: Singer 7469 Confidence sewing machine instruction
Make sure that the right large dial (which is the drive wheel for the motor) is engaged. You might have it set for winding a bobbin and the needle will not go down unless you have the right wheel pushed in.
Posted on Nov 10, 2009
Testimonial: "thank-you that was a fast reply when I really need one."
  • 1788 Answers
SOURCE: my feed dogs wont go
Sometimes you have have do 2 revolutions with your handwheel turning towards you. Always turn handwheel towards you. Try that.
Posted on Sep 26, 2010
  • 1788 Answers
SOURCE: My sewing machine isnt stitching
Return it to the store that you bought it and get another one. If, you bought it from a regular dealer, like JoAnn Fabrics they will help you out. You are under warranty, so if necessary take it to the authorized repair center. It should be free.
Posted on Nov 03, 2010
  • 11 Answers
SOURCE: Singer 6105 Tension knob
First make sure that the thread you are using in the bobbin is the same brand and type as in the spool that is threaded. I've read that using different weight threads at the same time can cause tension problems. I have actually had this problem and following this advice it went away. If this doesn't work you may need to have the machine serviced, unless someone else in the forum can advise otherwise. Good luck.
Posted on Jan 14, 2011
Thread started bunching on underside of project & tangling around bobbin. Now the needle won't pick up bobbin thread, even after changing needle 2x and re-threading upper thread. What's wrong?
Hmmm, could be several things.
Try a brand new needle. Try a different brand of thread.
Remove the top thread from the machine. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still will not pick up the bobbin thread, the machine could be out of time.
Jan 19, 2018 | Singer Sewing Machines
?I HAVE A ZUKI TL-2010Q. IT WORKED UNTIL I HAD TO CHANGE THE BOBBIN.NOW THE TOP THREAD KEEPS BREAKING.I HAVE RETHREADED THE TOP THREAD SEVERAL TIMES,WITHOUT ANY CHANGE IN THE SEWING.
Remove both, the top thread and the bobbin from the machine.
Re-check your owner's manual then re- thread the bobbin and install it in the machine. (Make sure the bobbin is turning the correct direction.)
Re-check the instructions for threading the top thread.
ALWAYS RAISE the presser foot and re-thread the top thread following the thread path shown in the manual.
Start with the top tension set at the midway point between low and high number--then tweak it for your current project.
AVOID old or bargain bin thread!!!!
Sometimes, installing a brand new needle will help. A new needle should be installed every 8 hours of sewing time! A damaged needle will cause a great deal of sewing havoc but is really inexpensive when resolving sewing issues.
Dec 06, 2017 | Sewing Machines
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
Hi, I have a singer confidence 7470 sewing machine and the needle keeps hitting the bottom of the bobbin. I need to know how I can adjust the needle.
Try a brand new needle. If the old one is bent, that could be why it is striking. If the new needle doesn't resolve the issue, the machine most likely has a timing issue. You can search for multiple web sites and videos for discussions and instructions for sewing machine timing issues. Or you can take it for service.
Oct 04, 2016 | Singer 7470 Confidence Sewing Machine
Zig Zag stitch isn't consistent top stitch is sporadic
Remove all the thread from your machine. Make sure to clean around the feed dogs and bobbin area. Loosen the top tension disk all the way to zero & raise the presser foot. Dampen a piece of pearl cotton with rubbing alcohol and pull the pearl cotton gently down between the tension disk a couple of times. Consult your owner's manual and oil as instructed in the manual using ONLY fresh good quality sewing machine, applying 1-2 drops each spot indicated. Install a brand new needle. Avoid old, fuzzy, or bargain bin thread. With the presser foot in the RAISED position, rethread the top thread--verify it is threaded correctly. Reset the upper tension to about halfway between the high & low number. Make sure the bobbin case is threaded properly and verify the bobbin is turning the correct direction in the bobbin case. Install bobbin case in the machine. Test stitch on a scrap piece of fabric.
If it continues to malfunction, you may need to take it for service.
Dec 29, 2015 | PfaFF Creative 7570
Why does mi new sewing machine singer confidence 7463 not work
Check your manual for some troubleshooting tips. Something is not plugged in, or seated right, like the bobbin.
Here is a sequence of (comments) problems that others have had with this machine.
http://www.erinsayssew.com/singer-confidence-7463-sewing-machine-review/
Feb 28, 2015 | Singer Confidence 7463 Computerized Sewing...
My rs200 toyota sewing machine bobbin won,t take thread round to lift bobbin thread
At 8 months old must still be under warranty, so take it back before you have any more problems and get a replacement.
Jan 19, 2015 | Toyota Sewing Machines
Singer confidence sewing machine won't pickup bobbin thread
Make sure the bobbin is inserted into the bobbin case spinning the correct direction and rethread and try.
Oct 03, 2014 | Singer Confidence 7469 Mechanical Sewing...
Adjust the timing on a singer confidence quilter 7469q
Hook/needle timing needs a hands on guidance to get it fix, 2 options either you can watch in utube 'singer sewing machine hook timing' or 'google' for singer 7469q service manual for your referral.
Nov 10, 2013 | Singer Confidence 7469 Mechanical Sewing...
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
