Question about Panasonic KX-TD7896 Cordless Phone
The panasonic KX-TD7898 cordless phone display is blank.
I already powered the phone on and off and took the battery out and repaved it. Still nothing. Any suggestions?
SOURCE: Panasonic Cordless Phone Set KX-TGA1016
Yes, leave it on the charger all day, it will not hurt the life of the phone.
Posted on Jan 16, 2008
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: manual for panasonic kx-tg5240
Here's the manual (Adobe PDF) from Panasoni's site:
http://service.us.panasonic.com/OPERMANPDF/KXTG5240.PDF
Posted on Jul 23, 2008
SOURCE: Screen gone blank
I had the same fault with the handset losing it's display, phone worked great but could not see to access internal phone directory.
To strip down the phone you need a very clean hard plastic/granite
work surface and a small philips screwdriver and a small flatblade screwdriver.
First of all remove the battery cover and the batteries, put them in safe spot on the work surface (Tip: take the top cover off an aerosol tin to use for holding the screws and small parts you remove)
Remove the front facia by gently teasing it away from the body of the phone, there are 2 plastic lugs either side of the battery compartment, ease them towad the edge of the casing to release the front facia, it should then unclip easily with your thumbnail.
Near the edge of the phone you will see 2 small screws, remove them carefully and set them aside, please note these are longer than two other screws you will encounter later in the disassembly.
Seperate the two main parts of the case from the battery compartment end of the phone and work towards the other end, there are two release points on the outside of the casing, gently insert a small driver into the recess whilst applying a small amount of lifting pressure between the two casing halves and it should spring open. (Note that the case hinges on a clip at the top edge of the phone which helps with its re-assembly later.)
Please be aware that the speaker wires are soldered to the main board and should not be disconnecetd or cut!!!
At the battery end of the phone is a small strip of white plastic tape covering two short screws, these hold the cradle charging contacts to the circuit board, remove them with the metal contacts and keep them safe.
With a little coaxing the rest of the phone should now come out of the casing. Be very carefl not to touch any of the gold contacts on the circuit board or the buttons may not work, you may gently clean these using a dry microfibre cloth. DO NOT SCRUB THEM, simply rub gently a few times.
Unclip the display holder andnote the earpice comes loose, this can be fed through the plastic holder byturning it sideways and pressing it through. DO Not damage wiring!
You should now see the tiny ribbon cable on the display itself, either side of it are a thin white plastic lug which can be slid carefully away from the edge of the display to release the cable. Remove cable gently and re-insert it back into the connector it came from, ensuring it is fully home and is perfectly aligned at right angles to the display, then carefully slide the retaining lugs back into place which will lock the cable back into place.
You can now re-assemble the phone, carefully.
It worked for me, hopefully it should for you unless the display is damaged prior to or during disassembly.
Posted on Mar 09, 2009
sodeep
  • 3267 Answers
SOURCE: english manual for Panasonic KX-TG1100CE cordless phone
You can downoad it from this link: http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg1100ne_kxtg1102ne_kxtg1103ne.html or you can buy a copy from : http://www.cordless-phones.uk.com/cordless-phones/digital-cordless-phones/panasonic-kx-tg1100-phone
................................................sodeep
Posted on Jun 23, 2009
Handset display lights up but is blank
If the batteries in handset are old then replace it. Follow battery change instructions in this manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.pdf
Sep 12, 2014 | Panasonic Lands Phones
Panasonic KX-TG6711E Cordless phone
Have you check another phone jack in the home? sometimes it is a bad jack that cause it not to work
May 13, 2014 | Panasonic KX-TG4500 Phone
110v base plugged into 220v
Hi Allen,
Yes you can fix.
please go to repair personal with power adapter or buy same type one or by alternative power adapter but output must be same as the original and 220v as in .i think buying new one is a good idea.
regards,
nuwan.
Jan 09, 2014 | Panasonic KX-TG9341T Cordless Phone
No display panasonic cordless phone
The display on that particular phone may have to be replaced.
Dec 28, 2013 | Lands Phones
I have not used my Panasonic KX-TCD200CX cordless a Month. Now when I plugged it in, it does not seem to be charging. The screen is blank even after 5-6 hours of charging.Please advise what I should do...
Possible that the battery Voltage has gone BELOW the THRESHOLD level and so will take a long time to come up so that the display light ups. It is best to see if the battery is leaked, damaged or the connectors clogged. Test the voltage on the battery and replace if the voltage is low. Also keep the phone plugged on overnight so that the circuit warms up and clears all disturbances.
Jun 17, 2011 | Panasonic GigaRange KX-TG5432 Cordless...
I have a panasonic KX-TG5431and for a cordless i have no link to base and the cordless off. the battery is slow after charging. Thanks
Hi, I have the same problem. My set is Panasonic KX-TG6522C. Please let me know how you fixed this issue (if you already have)
Dec 13, 2010 | Panasonic KX-TG5431 Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Feb 11, 2007 | Panasonic KX TC1740 Cordless Phone
Panasonic KX-TD7896 Cordless Phone Logo
119 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
