i have a tricity bendix washer aw1000 and it wont spin.i put the wash on and when it gets to the rinse it wont go on it.it makes a pumping noise then turns itself off,it also wont spin.help!!!
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Was this helpful?
Yes
No
Popular Solutions for Tricity Bendix AW1000W Front
I have a Tricity Bendix AW1000 it finnished a cycle, but still had a lot of soapy water in it. When...
(More)
I have a Tricity Bendix AW1000 it finnished a cycle, but still had a lot of soapy water in it. When I tried to run a rinse, it didn't do anything. It would sit for 10 minutes before end lit up?
My mother's Tricity Bendix washing machine, AW1000w does not appear to rinse properly. Her towels...
(More)
My mother's Tricity Bendix washing machine, AW1000w does not appear to rinse properly. Her towels always feel like toast! Although she uses a minamal amount of detergent, I notice that on the washing cycle it produces a huge amount of suds. She has a water softener. She has had numerous plumbers and washing macine repair people in; generally they say it's the water pressure and have adjusted this accordingly. She has even had new taps fitted. None of this has made any difference. What can we do?
