Question about Fagor Washing Machines
Code c03 appears on display of fagor fwm714it washing machine
3 Suggested Answers
  • 193 Answers
SOURCE: Fagor Integrated Washing Machine FWM714IT error
After inspecting and cleaning the pump filter, unplug unit for 20 minutes
Posted on Nov 12, 2009
  • 6277 Answers
SOURCE: our fagor fwm714it washing machine
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 27, 2011
What does error P03 mean?
Hi,I cant be a hundred percent shore,but I think that it means ( fuel voluem regulater control curcuit low )I hope I am not steering you in the wrong direction,I have a code gide and this is it if im reading it write,all the best.
Sep 14, 2015 | Fagor Washing Machines
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
Fagor Elegance FE 538 washing machine. A copy of operating manual pl.
i dont know how to use that machine.. FAGOR Elegant FE-538 ..
neet guide or manual ....
Jun 15, 2011 | Washing Machines
Our fagor fwm714it washing machine door will not open after the cycle finishes or when turned off. the machine has been showing the error code F07 of late.
John C
Feb 27, 2011 | Fagor Washing Machines
F02 error code on Fagor FU6146IT
attempted to look up your washing machine on www.repairclinic.com they don't list Fagor, but you can go to that site and do some research. That website lists error codes for countless appliances as well as troubleshooting guides for the codes. Good luck
Jan 07, 2010 | Washing Machines
Fagor Integrated Washing Machine FWM714IT error message F08 how can this be reset?
Nov 07, 2009 | Washing Machines
Error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
Jul 14, 2009 | Washing Machines
F02
you might try here fill in your model and search for user manual download
http://www.fagor.com/mun/_bin/ingl/downloads2.php
Mar 28, 2009 | Washing Machines
Question: FAGOR FE-1158 ELEGANCE WASH MACHINE
We have a 1 yr old Bosch wash machine w/o problems till now. We have a problem with the centrifuge program-it does not start, although the machine can spin slowly. Is it a motor problem or a problem with the programmer? Thanx for the help in advance!
Oct 16, 2008 | Washing Machines
Washing Machines Logo
621 people viewed this question
Top Fagor Washing Machines Experts
Vernon Taylor
ray gallant
Are you a Fagor Washing Machine Expert? Answer questions, earn points and help others
