Question about Nikon Zoom-Nikkor 18-200mm f/3.5-5.6G ED-IF AF-S VR DX Zoom Lens for DX Cameras
Nikkor 18-200VR AF rattling noise and judders when locking on
When my Nikkor 18-200VR focuses, I hear a rattling, rumbling and juddering noise. This is not the VR. (VR only makes a clicking noise.) I know it's not the silent wave motor because when I put the lens cap on, the focus spins from infinity to zero with a quiet swish like sound. When I take the cap off to focus (and swith off VR), it rattles and rumbles and to the focus lock on point. I've not used my D300 & 18-200 VR for a week or so but don't recall hearing this much noise from the unit. Has any body experienced this?
  • fatboy_paul Jan 09, 2009
    I have the same problem with my New D300 and 18-200 VR lens. If make s clunking sound when the VR is activated and parked. I did not experience this with my D200 and previous 18-200 VR lens. I went back to the camera shop and contacted Nikon. Both stated this is normal. It is not normal to me, I do not like it. The noise it irritating. There are many other article on the internet with people having the same issue.
    Paul
SOURCE: Camera won't autofocus
I too had D50 autofocus problems and ended up buying a new D300. I then learned that my issue was in the focus areas. The D50 has five focus areas. As you look through the lens, you will see one rectangle in the center and four to the top, bottom, left and right. You should make sure that the center rectangle is highlighted. Use the round thumbdial on the back of the camera to move the focus area.
Posted on Oct 31, 2008
americandove
  • 3 Answers
SOURCE: Sigma 70-300 Macro Motorised Lens for Nikon has stopped autofocus
If you just purchased the lens I would take it back sounds like the lens is jarred and defective should still be on warranty
Posted on Jan 24, 2009
SOURCE: Best Auto focus Tele For Nikon D40
hi ! iam too a D40 holder,u can opt for AF-s versions or HSM sigma,both of them autofocus on d40,can go for 18-200 AFs VR or if u need still longer end go for 70-300 but it is costly than the sigms 70-300APO DG HSM MACRO..,its a much better reviewed lens and dont forget the cost..anyway do some research before considering..good luck
Posted on Mar 16, 2009
skidzy
  • 65 Answers
SOURCE: rattle sound in lens, wont take pictures
Your lens has an aperture issue,sounds like you may have an element of glass not locking into place correctly.
Options are;
Send to manufacturer for repair.
Or back to the shop if under warranty.
If the lens has been dropped...its probably on its way out now.
Does the camera work with other lenses ?
Posted on Nov 11, 2009
  • 181 Answers
SOURCE: nikkor af-s 18-200 VR not focusing
Please check your focus settings in the camera menu. Play around with the focus point from Single to 11 points. Also, try Auto mode as a quick way to test if the focus is working
Posted on Jan 04, 2010
My jeep Cherokee judders when I do between 20-30
Could be anything. Start by having your tires checked.
Sep 01, 2016 | Jeep Cherokee Cars & Trucks
Judder when focusing - how to repair?
Assume other lens work fine on this camera. Will have to go to a lens repair shop. There is NOTHING a mere mortal can do. I use KEH in GA. The are honest and reliable, and cheaper and faster than Nikon.
May 30, 2014 | Nikon Zoom-Nikkor 18-200mm f/3.5-5.6G...
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
My 1.2 ibiza is burning oil was making loud tapping noise topped oil up now juddering but no tapping
I can't find any explanation of the work "juddering" so please explain what it means. Thanks wait to hear from you.
Jul 11, 2012 | Cars & Trucks
My car is shaking and rumbling when driven
Rumbling is probably wheel bearings... nothing can be done except replace, can be done D.I.Y but a bit tricky.
If its judder then its probably no more then wheel balancebut as you said you got both therefore STRONGLY suspect wheel bearings i am gueesing this is on the front
Nov 18, 2010 | 2004 Ford Focus
Nikon 50mm 1.4d does not focus. I can hear the motor make a noise and if I Help it, it will turn. Also it seems stiff when off the camera and you rotate the focus ring.
Sorry to hear about your nifty 50 lens problems. The auto focus motor might have given out and needs repair. You should be able to focus manually with the lens.
Apr 26, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
I've a freelander td4 yr04 just had it a month and it's starting to judder some times shucking black smoke out when apply more power and theres a rattling noise
Faulty Injector or timing
If the injector is not spraying correctly you will be burning neat diesel out of the exhaust.
The effect of one cylinder missing will make the judder
If you bought it from a dealer take it back if you bought it off the street find a good fitter
Sep 20, 2009 | 2004 Land Rover FreeLander
Trouble with auto focus nikon auto nikkor 60 mm f2.8D
Lock it at f/32. Autofocus lenses have a lock for smallest aperture (highest number) because that is wht the camera body expects. The lock won't engage at any other position.
Feb 15, 2009 | Nikon Telephoto AF Micro Nikkor 60mm...
Juddering on power steering!
have you tried cleaning out CV joints and putting more greece into them?
Feb 01, 2009 | 2000 Ford Focus
55-200mm VR focus noise
The lenses have a focus motor built into them.when the camera is set to auto focus, once you press the shutter button, the motor activates to set the correct focus. VR is for motion stabilization. Turn off AF on lenses and camera and see if noise stops.
Dec 12, 2017 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Nikon Zoom-Nikkor 18-200mm f/3.5-5.6G ED-IF AF-S VR DX Zoom Lens for  DX Cameras Logo
388 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
