Indesit w161 wiring diagram
Require indesit washing machine wiring diagram to solve overfilling problem - pressure switch chamber is clear of obstruction.
  • 3 Answers
Here is your Indesit W161 wiring diagram, Please answer the easy survey then the link will be unlocked (the survey is for my efforts looking for your request)
http://bee4.biz/v/k6K7X
Posted on Feb 09, 2012
I have an old Indesit washing machine .Last night I put it on and went out .When I cam eback the Door lock light waqs falshing . Iturned the dial and off it went again from the start only to findthe l
It sounds as though the pressure chamber is blocked which is holding the pressure switch in the on position and in this situation the valves will stay energised. If you don't know where the chamber is then locate the pressure switch and follow the small bore hose from it down under the tub and it will take you to the chamber, remove it and clean it out don't just remove the hose and blow through the hole because this will only work for a few washer before it blocks again
Mar 28, 2017 | Indesit Washing Machines
What eroor8 in weat point washing machine
Error 8 Washing machine has detected an
overfill situation This error code can be caused by
overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as
the pressure sensor will falsely read
that there is too much water in the
washing machine. Also check the pressure sensor and
that the machine has not actually
overfilled with water. Check for overfoaming or over
soaping Check the air chamber and the
pressure switch hose Check water level sensor Check wiring to water pressure
sensor Check connections to water level
sensor Check main electronic controller
Jul 14, 2013 | Washing Machines
How do you fix fe error
LE means washing machine electronic controller has detected an overfill situation
* check for over foaming or over soaping
*check the air chamber and pressure switch hose for blockage
*check water level sensor
*check wiring to water pressure sensor
*check connections to water level sensor
*check main electronic controller
Nov 07, 2012 | LG Washing Machines
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Too much water going into the machine indesit wil103 water coming out the drawer when the drum turns.
Could try pressure switch/ clean the pipe feeding it check for hole in it causing air leak and pressure drop, make fill valve overfill
Apr 20, 2010 | Indesit W 123 Front Load Washer
Hi my ariston a1636 doesnt seem to pump water out it is now full to the brim and wont open the last two or three washes water came seeping out the draw is there a blockage in my pump
Could be but think more of an overfill fault cased by a blockage @ the pressure switch this controls the level of water in the drum shutting off fill valves. The pressure switch or air switch operates at 3 psi it is round with wiring onto it and has a tube connected to it ....make sure the Tube and chamber tat feeds this is clear as this is common to fail the valve and result in overfill,Apart from a faulty fill valve of course, this should cut off when power is removed.....good luck
Apr 15, 2010 | Ariston Technologies AWD121WH
Indesit washing machine W1A 121 no red light when
Select reset from front panel and reset timer. you may needalso to cure water level fault as its overfilling. could be dirty air hose to pressure switch...
Nov 13, 2009 | Washing Machines
Indesit wahing machine WIE 167 keeps filling with water and did flash H2O have replaced the switch mechinism inside but to no avail tube is not punctured or coroded - will not go onto wash cycle but will...
You need to clear out pressure chamber the part the at tube plugs into the chamber it will be clogged, stopping air going to pressure switch...This should cure..
Oct 07, 2009 | Washing Machines
Machine stuck on F08 what is solution? Hotpoint WT965
F08 indicates "Heater Relay stuck or Pressure Switch stuck on full".
You'll need a multimeter to be able to carry out some checks.
Check the heater for continuity, you should get a reading of around 25 ohms.
Check the pressure switch connections on the main pcb, usually J3
Check the pressure switch wiring and connections.
Chek the wiring at the heater for internal breaks. (The wire looks ok but when pulled snaps easily).
Check the pressure tube and chamber.
Unplug the appliance from the wall socket.
Take the lid off and locate the pressure switch.
Take off the thin tube attached to it and blow down the tube to try and clear any restrictions in the pressure hose or chamber.
Refit the tube and try the machine again.
If everything checks out ok, it would suggest that the main pcb will require replacing and the software written to it.
Thanks
Sep 08, 2009 | Washing Machines
Washing Machines Logo
386 people viewed this question
Top Washing Machines Experts
